b18a1 in 90 not gettin fuel, help!
Old Oct 12, 2005 | 11:34 AM
LShatchie's Avatar
Default b18a1 in 90 not gettin fuel, help!
Just swapped a b18a1 in a 90 hatch and its not getting any fuel at all to the fuel lines or even the filter, just replaced filter and main relay. You can hear the fuel pump prime when you turn the key. What else could the problem be?? Car starts right up when you spray starter fluid, just isnt getting gas... help need to fix this
Old Oct 12, 2005 | 11:44 AM
CRXb18Turbo's Avatar
Default Re: b18a1 in 90 not gettin fuel, help! (LShatchie)
seems like a injector problem.
Check to see if fuel gets to the rail?
Old Oct 12, 2005 | 12:27 PM
LShatchie's Avatar
Default Re: b18a1 in 90 not gettin fuel, help! (CRXb18Turbo)
like i said fuel is not even getting to the fuel filter, filter is dry and the line to the fuel rail
Old Oct 12, 2005 | 12:55 PM
LShatchie's Avatar
bump this bia
Old Oct 12, 2005 | 01:13 PM
if it don't get the the filter then check the pump.
pump prime doesn't mean it's sucking gas to the line.
RAN OUT OF GAS?????
Old Oct 12, 2005 | 02:22 PM
LShatchie's Avatar
ok well i just dropped the tank and im about to pull the pump out and check it out.. what should i look for? or just replace?
Old Oct 12, 2005 | 03:10 PM
just replace it while you are at it.
it's about time to replace a 15 year old pump.
Old Oct 12, 2005 | 03:12 PM
oh one more... don't forget to replace that filter bag ( whatever that call ) at the end of the pump.
maybe that is clog up.
Old Oct 12, 2005 | 04:43 PM
LShatchie's Avatar
aight sounds good. putting a new pump on now lets she if she fires up... umm cross your fingers, pray do anything to get my motor started.. hehe
Old Oct 12, 2005 | 05:19 PM
sleepin91teg's Avatar
Do you have and CELs...did you just do this swap and not hook something up correctly? Grounds are a big deal with this, but like stated above it does sound like a pump, so replace the pump and if it doesnt work, then come, cuz theres many things that could be wrong still! Good Luck
Old Oct 12, 2005 | 08:05 PM
LShatchie's Avatar
Default Re: b18a1 in 90 not gettin fuel, help! (sleepin91teg)
ok it runs now, changed the fuel pump, but i think it was because there wasnt any gas in there the whole time! o well
Old Oct 12, 2005 | 08:14 PM
hb_guy's Avatar
checj your ground on the thermostat from your harness, it is under the distributor, i always overlook that ****, keep us posted, gl
Old Oct 13, 2005 | 08:01 AM
LShatchie's Avatar
Default Re: b18a1 in 90 not gettin fuel, help! (hb_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_guy &raquo;</TD></TR><TR><TD CLASS="quote">checj your ground on the thermostat from your harness, it is under the distributor, i always overlook that ****, keep us posted, gl </TD></TR></TABLE>
like I stated above, problem solved... shes alive !
accordexdude25
Sep 7, 2014 07:09 PM
hermtm2
23
Apr 8, 2009 06:17 PM
B-Rex
Jan 22, 2009 06:19 PM
crnimacak
Apr 21, 2006 10:11 PM
shift6
Sep 7, 2004 09:39 PM
