93 si axle nut ???
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlsFinest »</TD></TR><TR><TD CLASS="quote">how the *** do u get that thing off i weigh 215lbs and i was jumping on my breaker bar and i still cant get aht bitch loose!
im replaceing my wheel studs and i cant etteh axle nut loose</TD></TR></TABLE>They are on there pretty tight (134 ft/lbs). I have always used an impact but just make sure to bend out the part of the nut that is punched in to keep it from spinning off. Usually that is where those ******* get hung up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">why you removing the axle to replace the wheel stud anyways?</TD></TR></TABLE>
I haven't heard of any way to replace wheels studs without pulling the hub off the knuckle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">They are on there pretty tight (134 ft/lbs). I have always used an impact but just make sure to bend out the part of the nut that is punched in to keep it from spinning off. Usually that is where those ******* get hung up.</TD></TR></TABLE>
good luck getting to the nuts wothout removing the axle...
anyways 1/2 inch gun- about 400+ pounds of torque should do!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 »</TD></TR><TR><TD CLASS="quote">
anyways 1/2 inch gun- about 400+ pounds of torque should do!!!</TD></TR></TABLE>Hmm, I don't see how you would remove the axel BEFORE removing the big *** 32MM that holds the axel. You know, the one he is talking about? Anyway..
I'm surprised you haven't gone through a couple breaker bars already trying to get it off. But even a basic air gun will get it off. Just bend the part of the nut that is punched in by using a flat head screw driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">remove rotor, drive them out the back, insert new stud.
A trick I learned from a dealership mechanic.......</TD></TR></TABLE>
drive them out the back?? isnt the dust shield in the way??
RCautoworks
48
Nov 27, 2006 12:26 AM
