Axle nut removal
Axle nut removal
im in the process of replacing my axle on my 95 civic EX.
however, i cant get the 32 mm axle nut off. the whole thing turns whenever i try to loosen it. the pass side wheel is on the ground, FYI.
do i have to get a driver or big *** pipe? (im using a big *** pipe right now.)
Re: Axle nut removal (maskedSONY)
what do you mean the whole thing turns?
both wheels flush on the floor, use a breaker bar to help with the leverage.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maskedSONY »</TD></TR><TR><TD CLASS="quote">and i wish i knew that before. so do i have to fully tighten the wheel bolts on before i start twisting away at the damn axle nut?</TD></TR></TABLE>
nah, just make sure they are snug. Also, put a rag on the breaker bar if you need to protect your wheels.
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">i had my roomate step on the brakes while i used a 3' breaker bar. it was pretty easy </TD></TR></TABLE>
easiest way to do.
easiest way to do.
Re: (sleeperciv)
okay now im trying to remove the lower ball joint's castle nut - however i did not see a cotter pin there - is there one suppose to be there or not? the nut is pretty greasy and after cleaning it a bit i couldnt see it.
Re: (DANE)
okay well i got that nut off, and i removed the bolt that secured the fork to the lower control arm. however, i can't get the lower ball joint loose. I dont have enough space to whack it with the hammer i have.
any ideas on how to beat the damn thing so it will come off? or is there anyway for me to swap the axles without having to get the lower joint freed?
Re: (maskedSONY)
RCautoworks
48
11-27-2006 12:26 AM
teamvirus
12-17-2005 02:56 PM
