how to remove my hubcaps, 2000 4 dr LX accord
it might be possible to take them off without removing all of your lugnuts, but it is not possible to take them off, without breaking them, unless you remove all or some of your lugnuts. Look at the lugnuts, there is a possibility that only 2 of them will have black washers connected to the lugnut, this is what holds the hubcap on. You only need to take the lugnuts off that have this washer on them to get the hubcap off. It isn't that difficult to remove the lugnuts, when you put the lugnuts back on you should torque them to 80 ft. lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">Impressive.. worst thread ever
Not all of us know everything about cars, so take it easy.
</TD></TR></TABLE>Not all of us know everything about cars, so take it easy.
this is not the worst thread ever.... sometimes people just have never tried something and are afraid that if they do try it, they'll expletive up.
better know before-hand than after, right? can't be hard on someone who asks for help.
loosesn lugs while on the ground
jack car up and remove lugs and remove wheel cover
reinstall lugs and tighten enough to ensure wheel is all the way on
lower car
torque lugs to spec
repeat for other 3 wheels
lower car
torque lugs to spec
On my '99 LX, which I assume is the same as the '00 LX, you have to remove the four lugnuts. Jack up that part of the car and just take off the lugnuts.
By the way, if it scratched up, faded, or whatever, a new hubcap is only ~ $15 or $17. If they are beat up a little, you only need to replace two at a time (on the same side of the car) which will make the car look much better; I've done this before.
omg my roommate and i had the same problem with taking the hub caps off.. haha.. we tried pulling that crap off but all it did was warp the hub cap.. then we realized we had to take off lug nuts.. wat a pain in the ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Negronese »</TD></TR><TR><TD CLASS="quote">omg my roommate and i had the same problem with taking the hub caps off.. haha.. we tried pulling that crap off but all it did was warp the hub cap.. then we realized we had to take off lug nuts.. wat a pain in the ***</TD></TR></TABLE>
ar..yes and no..those lugsnutskeep those poor hub from flying all over the road, hey i do ANYTHING to keep my bling bling 14 inch plastic spinner.
if you don't like those, just swap in some old lugnuts.
thekid_12
Mar 25, 2008 03:31 AM
