Help: Civic has no power to starter or accessories.
The other day, I left my lights on in my 94 civic ex. I tried to jump it, and could not get it to even turn over. None of the interior lights or radio worked either. I firgured the battery was totally dead, so I tried using another working battery, and got the same results. The car is getting no power at all, and is acting like there is no battery hooked up. I checked all my fuses, as well as the connections on the battery. Has this happened to anyone before? Any ideas what I should do next? Thanks.
Did you check the main one under the hood, its a 80 amp fuse. Other then that check your ground wire and positive to the fuse box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR9788 »</TD></TR><TR><TD CLASS="quote">Thanks. Anyone else?</TD></TR></TABLE>
What happened when you tried what people listed above?
BB6Driver
Honda Civic (2006 - 2015)
Dec 1, 2018 08:30 PM
ekHatChAddIcT
15
Mar 16, 2011 06:58 PM
c for sea
21
Aug 12, 2005 06:38 PM
