jdm d15b vs d16z6
Old Oct 12, 2005 | 07:43 AM
jdmallstar2000's Avatar
Default jdm d15b vs d16z6
i recently found a good ek shell. the shell is
already wired for vtec and i and i want to drop a
single cam in for the mean time. my budget for the motor
is $500 i was wondering what are the pros and cons of both
engines i belive the jdm d15b has 130hp @ 7200rpm.. i searched
the HT archives and only found info on the d15b its self didnt really
find a comparison between both motors w/e.. help me out.
Old Oct 12, 2005 | 09:07 AM
Default Re: jdm d15b vs d16z6 (jdmallstar2000)
anyone??
Old Oct 12, 2005 | 11:56 AM
FalkenSiR's Avatar
if you get a d16z6 you would run a y8 ecu (forgot code), but if you get a d15b, then you can run it but it wouldn't run perfect. You would need to tune it. OR find a rare JDM 96-00 D15B ecu, which do exist. I know for a fact they came in some ferios.
Old Oct 12, 2005 | 12:53 PM
p28?
Old Oct 12, 2005 | 01:19 PM
Mista Bone's Avatar
D Tranny Guru
D15B is 130ps, or about 125 hp, same as the Z6 but with less torque.
Old Oct 12, 2005 | 01:46 PM
oh wow d15b has less tq! wack idk you think i can afford a d16z6 my budget is $500!
Old Oct 12, 2005 | 09:52 PM
anyone?
Old Oct 12, 2005 | 11:15 PM
Cuda70's Avatar
Default Re: (jdmallstar2000)
I recently got a D16Z from HMotors. With shipping it cost my $682.00.
I was very happy with what I received.
The only thing I did was replace the timing belt (Which I highly recommend) and record the milage so you know exactly where you are concerning the belt.
Since is was a JDM from USDM engine swap in a Civic EX I had to swap out the O2 sensors (JDM has one wire, USDM has 4)
Other than the timing being 3 degrees off it was a turn key easy project.
Now here is my personal thoughts on HMotorsOnline.
They are the best! Friendly, helpful, and easy to work with. The engine I got was in great shape, and from all the reviews I have ever read about them, this is normal, not an exception to the rule. The D16Z I got was a peppy replacement for the worn out D16 in my Civic. The particular one I got was from an automatic transmission application, so I had to use my M/T and clutch assembly; no problem.
Delivery: They are located in California, I am in Ft. Worth Texas. I ordered my engine on a Friday afternoon and they told me it would be seven working days for delivery. So, at 10 AM on the next Monday, I was quite surprised to receive a phone call stating my engine was waiting at the shop! Heh! I took vacation time for later in the week because I really figured it would be a full 7 days for them to deliver!
I give HMotors a 10 out of 10 stars and will use them again in the future if I have the need/get a chance. I have already recommended them to several friends than plan on making purchases from them in the near future.
I doubt you will find a cheaper, better engine for your car with equal miles on it.
Oh, BTW: Dont snap off your old O2 sensor like I did (The damned thing was rusted in place!) because they arent giving those little buggers away for free! heh
Old Oct 13, 2005 | 10:56 AM
ok so if im swapping a d16z6 into my ek what mounts will i need to get?
Old Oct 13, 2005 | 11:36 AM
can i use the stock ek mounts?
Old Oct 16, 2005 | 11:17 AM
EGsiR94's Avatar
yeah the stock mounts will work fine for you.
Bisimoto
Mar 18, 2009 11:14 PM
allricedout
50
May 31, 2007 10:27 AM
f150harleytruck7
Dec 1, 2005 09:40 AM
CivicHP
Sep 7, 2005 08:42 AM
del_sol
Mar 26, 2003 07:21 PM
