5th Gear Slipping
Old Oct 12, 2005 | 03:23 AM
hybrid0006's Avatar
Default 5th Gear Slipping
So finally got my clutch working, etc. etc.
Get on the freeway to break in my motor before I get it tuned. And after about 30 miles 5th gear starts slipping every so often. Then we make a pit stop, fill up on gas, check the oil. Get back on the freeway and it does it about every 20 seconds, making it impossible to continue.
What are possible problems?
Modified by hybrid0006 at 4:34 PM 2/27/2006
Old Oct 12, 2005 | 11:49 AM
Burke's Avatar
Banned
Default Re: 5th Gear Slipping (hybrid0006)
what clutch????
Old Oct 12, 2005 | 02:16 PM
hybrid0006's Avatar
Default Re: 5th Gear Slipping (Burke)
Exedy.
Could it be low fluid?
Old Oct 12, 2005 | 02:35 PM
Burke's Avatar
Banned
did you break it in?? how much boost, have you bled the clutch (shouldnt really matter though) what pressure plate are you using? what motor??
Old Oct 12, 2005 | 03:55 PM
hybrid0006's Avatar
It already had 1000 miles on it. Pressure plate came with the clutch I bought.
Its a b16 motor. I am going to try and fill the tranny fluid.
Old Oct 12, 2005 | 04:00 PM
Burke's Avatar
Banned
your tranny fluid wont have any effect on your clutch.
which exedy is it?? honestly, it is probably your clutch cant handle the power of your turbo.... and VTEC!!! sorry i had to.
it will start slipping in 5th, the worse it gets, it will then start to slip in 4th and then 3rd. i just replaced my centerforce dual friction (it blows) with a clutchnet 6 puck sprung and heavy duty pp and its awesome!
good luck
supercivicstack
Sep 12, 2009 02:24 PM
niceprelude
Nov 7, 2008 10:22 AM
02_Si_FTW
Jul 21, 2008 01:57 AM
spidermancivic
19
Jun 24, 2005 10:30 PM
LT6916
Jul 26, 2004 08:52 PM
