Castle nut rubbing on brake rotor
Old Oct 11, 2005 | 06:14 PM
opiumdaze's Avatar
Default Castle nut rubbing on brake rotor
Hey guys I had an accident a few days ago. I bent my front passenger LCA and I found out today that I bent my spindle. I replaced everything but now the bolt for the lower ball joint is scraping into my rotor. I can not figure it out. Please help me HT I've always counted on you guys for answers!
Old Oct 11, 2005 | 07:58 PM
t_c_l_6's Avatar
Default Re: Castle nut rubbing on brake rotor (opiumdaze)
what all did you replace?
Old Oct 11, 2005 | 08:01 PM
gsr dood's Avatar
bump. i have the same problem mine only rubs sometimes its weird
Old Oct 11, 2005 | 08:15 PM
opiumdaze's Avatar
Default Re: Castle nut rubbing on brake rotor (gsr dood)
i replaced my knuckle/spindle and LCA any ideas guys?
Old Oct 11, 2005 | 09:03 PM
KOALA YUMMIES's Avatar
Something else is still bent/damaged causing distortion in that joint. Inspect the upper A arms?
Old Oct 11, 2005 | 09:11 PM
opiumdaze's Avatar
Default Re: Castle nut rubbing on brake rotor (KOALA YUMMIES)
the upper control arms?
Old Oct 11, 2005 | 09:27 PM
Naruto's Avatar
I guess you could call it that, but they're refered to as upper "A arms"
btw...the pic looks like its showing your dust shield scraping the rotor.....
r_kage
Aug 30, 2016 01:35 PM
kenzo42
Sep 2, 2013 10:17 PM
92civicx
Oct 4, 2007 05:19 PM
opiumdaze
Suspension & Brakes
Oct 14, 2005 10:04 AM
opiumdaze
14
Oct 11, 2005 09:22 PM
