Help!! what's needed for b-series swap in 95 Dx?
Old Oct 11, 2005 | 06:06 PM
BoRiCuA's Avatar
Default Help!! what's needed for b-series swap in 95 Dx?
trying to find out what's needed for a b=series swap in 95 honda dx coupe. thanks
Old Oct 11, 2005 | 06:11 PM
sockvtec's Avatar
Default Re: Help!! what's needed for b-series swap in 95 Dx? (BoRiCuA)
omg i swear all these threads........SEARCH
please
Old Oct 11, 2005 | 06:43 PM
Type-X's Avatar
what kind of b series? vtec or non vtec? non-vtec ls is easiest and all you'll need is axles, motor, tranny, harness, mounts, and an eshaust upgrade. keep in mind that you can still use your DX ECU but it'll lack power. i suggest a P28 or a P30 ECU
Old Oct 12, 2005 | 04:05 PM
BoRiCuA's Avatar
Default Re: Help!! what's needed for b-series swap in 95 Dx? (Type-X)
ok how's about a d16 vtec? do i have to change the harness or any mounts? thanks
Old Oct 12, 2005 | 05:26 PM
hatchi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoRiCuA &raquo;</TD></TR><TR><TD CLASS="quote">ok how's about a d16 vtec? do i have to change the harness or any mounts? thanks </TD></TR></TABLE>
you can use the same harness or the one that comes with d16z6. you will need to run vtec wires though unless your chassis is a 92
Old Oct 13, 2005 | 06:15 PM
BoRiCuA's Avatar
Default Re: Help!! what's needed for b-series swap in 95 Dx? (hatchi)
so the only thing is the harness and wire vtec, but wait it's not multi point fuel injection it's a dx, does that matter what about ecu can i use the p06 with z6?
MGBej1503
May 6, 2012 11:00 AM
1sickeg8
16
Jan 10, 2010 03:18 PM
jdmsupreme2132
Dec 27, 2009 07:36 AM
nemesis25
18
Nov 1, 2008 07:36 PM
brokendx
Apr 30, 2005 02:42 PM
