Searched: Will B16 ExMani fit on an LS/VTEC?
Old Oct 11, 2005 | 03:38 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Searched: Will B16 ExMani fit on an LS/VTEC?
Just as the title reads, will a B16 exhaust manifold fit on an LS/VTEC swap.. I think I read somewhere it wont clear the oil pan, but I don't remember..
Modified by HondaFanatic708 at 7:04 PM 10/11/2005
Old Oct 11, 2005 | 07:44 PM
Default Re: Searched: Will B16 ExMani fit on an LS/VTEC? (HondaFanatic708)
TTT
Old Oct 11, 2005 | 08:26 PM
98 Spec R's Avatar
It will rub the oil pan you are correct.
Old Oct 11, 2005 | 08:40 PM
slomofo's Avatar
GDD Member
No
Old Oct 12, 2005 | 10:29 AM
Default Re: Searched: Will B16 ExMani fit on an LS/VTEC? (98 Spec R)
**** that sucks, looks like a DC header will be coming sooner than expected. Until then I guess my oil is going to get pretty hot.
Old Nov 3, 2005 | 01:58 PM
Will a B16 oil pan fix this rubbing problem?
Old Nov 3, 2005 | 03:24 PM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">Will a B16 oil pan fix this rubbing problem?</TD></TR></TABLE>
no because the deckheigh of the b16 block vs the ls or gsr block is different, i.e. the b16a is shorter.
greg
Old Nov 3, 2005 | 03:54 PM
4genaccordfreak's Avatar
^^ bingo.... LS block is longer due to its longer stroke.. you will need or would want to preferrably goto an ITR 4-1 header
Old Nov 4, 2005 | 09:46 AM
Default Re: (4genaccordfreak)
So I wouldn't need anything custom for the ITR header to match up with my cat? This is an EJ2 BTW..
Old Nov 4, 2005 | 03:20 PM
CHEETAH's Avatar
Default Re: (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">So I wouldn't need anything custom for the ITR header to match up with my cat? This is an EJ2 BTW..</TD></TR></TABLE>
itr/ls and b16a all land at aroudn the same place ... the GSR is the one that has a short downpipe and longer cat.
davidluko
Feb 12, 2009 11:58 AM
boosted_soul_94
Jan 31, 2006 06:44 PM
crxsi8
Dec 19, 2005 07:10 PM
B16'D DA9
May 29, 2005 01:32 PM
b18b-HB
Sep 6, 2002 05:18 PM
