A/C Compressor noise
Old Oct 11, 2005 | 02:41 PM
DaM[A]N's Avatar
Default A/C Compressor noise
hello, I have a 97 Accord Sedan V6 and I have got a high pitched constant whine coming from the A/C Compressor. Is there a lube/spray i can buy to apply on the pulley or is it best that I just replace the A/C compresor? The A/C works great just that loud whine is driving me nuts otherwise it works just fine
Old Oct 11, 2005 | 03:34 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: A/C Compressor noise (DaM[A]N)
Does it make more noice when the A/C is on, or does it sound the same in either case?
Old Oct 11, 2005 | 04:47 PM
deserthonda's Avatar
you might want to double chk it is coming from the compressor,, i have replaced a few alternators on the v6s for noise that it seems like coming from the compressor ......v6 alternators is a common noise problem .......
Old Oct 11, 2005 | 07:45 PM
DaM[A]N's Avatar
Default Re: A/C Compressor noise (deserthonda)
Same as on or off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">you might want to double chk it is coming from the compressor,, i have replaced a few alternators on the v6s for noise that it seems like coming from the compressor ......v6 alternators is a common noise problem .......</TD></TR></TABLE>
How can i check that? Swap out a new Altenator to see? (that is cheaper than a compressor)
Old Oct 11, 2005 | 08:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaM[A &raquo;</TD></TR><TR><TD CLASS="quote">N]Same as on or off.
How can i check that? Swap out a new Altenator to see? (that is cheaper than a compressor)</TD></TR></TABLE>
no no no do not replace any parts till u can verify what the actual problem is ,,,it could be very very costly,, Try this.......remove the belt, the same belt runs the alt and compressor, spin each 1 and se if u can hear which 1 is noisy.......if u cannot pinpoint it, take it to a honda shop it should be at no cost to you for their advice ....
Old Oct 11, 2005 | 08:06 PM
DaM[A]N's Avatar
ok, will do and thanks!
Old Oct 15, 2005 | 04:35 PM
Bendy817's Avatar
I dont know if you ever fixed that problem but you can also check the clutch gap.....or even the return springs.......if your gap is incorrect you can have noise or if your springs are going out then its not releasing properly.
Let me know
Old Oct 17, 2005 | 05:12 PM
DaM[A]N's Avatar
Default Re: A/C Compressor noise (Bendy817)
I tried removing the belt and the noise doesn't exists weird, I will take it to a honda shop for a look see.
Old Oct 17, 2005 | 07:06 PM
HondaTechPro's Avatar
I have also found it useful and easy to unplug the connector on the alternator with the engine running. Also of times a bad diode in the alternator can cause that type of whining noise, and unplugging the alternator will be like switching it off. Obviously you can't drive around with your alt unplugged, but it can help you pinpoint the noise.
Old Oct 18, 2005 | 09:13 AM
Bendy817's Avatar
Default Re: A/C Compressor noise (HondaTechPro)
its probably your bearings then........
gooeymax
Aug 30, 2018 04:33 AM
Hernst
Honda CR-V & Element
Sep 22, 2015 02:22 PM
Tank_EM2
Honda Civic (2001 - 2005)
Apr 2, 2015 09:00 AM
HGZ
May 29, 2008 12:51 PM
HONDA_TYPE_R
Acura TL, RL & ZDX
Sep 20, 2006 06:51 PM
