How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (civic VX)
Old Oct 11, 2005 | 12:40 PM
DaveFazari's Avatar
Default How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (civic VX)
I need help, i have a 92 civic vc and i put the si vtec motor in it and the computer that came with the motor doesnt work properly and when i put the vx computer in it works ok but not great. How do i fix that problem? do i need to change my 5 wire to 4 wire?? help me pls
Old Oct 11, 2005 | 12:43 PM
IHateJDM's Avatar
Default Re: How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (DaveFazari)
buy a 4 wire o2.
Old Oct 11, 2005 | 12:54 PM
DaveFazari's Avatar
Default Re: How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (IHateJDM)
I tryed that. the 4 wire o2 sensor doesnt fit in to the plug of the 5 wire
Old Oct 11, 2005 | 12:56 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveFazari &raquo;</TD></TR><TR><TD CLASS="quote">I tryed that. the 4 wire o2 sensor doesnt fit in to the plug of the 5 wire
you need to change the plug, or just solder it in.
Old Oct 11, 2005 | 12:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
i used this on a 1 to 4 wire conversion, but i would think it would be the same. i used it and it worked flawlessly.
http://www.hybridautomotive.com/tech/o2/#seven
Old Oct 11, 2005 | 01:08 PM
DaveFazari's Avatar
Default Re: How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (boostedcivicsir)
Thanks, then do you think that the computer i want to put in will work?
Old Oct 11, 2005 | 01:10 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveFazari &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, then do you think that the computer i want to put in will work?
what is the ecu code?
Old Oct 11, 2005 | 01:12 PM
dturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hybridautomotive.com/tech/o2/#seven</TD></TR></TABLE>
I used that for my VX to EX o2 wiring. Works perfect!
randyqnt
Oct 16, 2008 08:08 AM
SPOON_BeIgHtEeNsEe
Mar 3, 2008 03:26 AM
lv6l
Dec 14, 2005 04:04 PM
5STAR3
Mar 24, 2004 09:09 AM
