Weird Hissins noise while priming fuel pressure
Old Oct 11, 2005 | 11:59 AM
crx_88_si's Avatar
Default Weird Hissing noise while priming fuel pressure
Ok, just noticed this on my car today, not sure if it's normal.
My car had a weird miss earlier today after a cold start. Almost liking running on 3 cyl, kinda sounded like "bap bap bap bap bap".
a couple of revs and it went away. ??
Well, at home I decided to poke around for a loose plug wire or something. I turned the car off and poked around, found nothing out of the ordinary. Then i primed it, thats when i heard a weird hissing type noise from the engine bay (during priming, on and off w/ the CEL during initial key on).
First thing popped into my mind, fuel leak! So i looked around with it still in the ON position, and found no signs of fuel. Cycled the key a few times and this happens everytime.
Is this maybe a normal sound? (car was warm still). Can some1 w/ all the emissions junk do a test for me. Open your hood, prime the fuel psi, listen for a hiss from the engine bay. Thanks.
1. All emissions crap is as honda made it. Nothing removed.
2. No sign of fuel leaks, fuel level not dropping more than usual as per guage.
Thanks guys.
Old Oct 12, 2005 | 04:06 AM
crx_88_si's Avatar
Default Re: Weird Hissing noise while priming fuel pressure (crx_88_si)
No one?
phelpsj2
Sep 20, 2011 08:06 AM
kevinoneill
Mar 11, 2011 04:34 PM
TeamCracka
Apr 16, 2004 08:25 PM
bruthaboost
Sep 11, 2003 09:26 AM
