why dosn't check light turn on?
Old Oct 11, 2005 | 11:43 AM
alexsracing's Avatar
Default why dosn't check light turn on?
when you put key forward the light dosn't blink on then off.
but bulb is good
car turns on but if you give it gas runs crappy
1999 civic ex with 97 b16a running a 99 integra gsr ecu
Old Oct 12, 2005 | 04:15 AM
JimBlake's Avatar
Default Re: why dosn't check light turn on? (alexsracing)
The CEL bulb should always have battery voltage when the key is on. The ECU closes the ground side of the bulb circuit. Check that.
Then check whether the bulb is wired to the proper pin of the ECU plug. I don't have a '99 Integra wiring drawing, so I don't know which pin it's supposed to be.
Old Oct 12, 2005 | 02:58 PM
T4eg's Avatar
did u buy the car like that? If so the owner could of removed the bulb. Just an idea
kid_02131
Sep 9, 2012 07:42 PM
cuseikan
Aug 18, 2008 01:26 PM
Cameron60
Jan 16, 2007 08:03 PM
Acc99ord
Dec 18, 2003 09:42 PM
phatcivic99
Jun 20, 2002 01:53 PM
