Starter problem?
So lately i have been having trouble starting my car? I dont have to try numerous times. Just turn the key once but def sounds like it takes some time for it to start. And sometimes makes a screeching noise once it starts.
On top of that when i turn the car off i hear a ticking sound slowly whining down. Like something spinning? What do you guys think, thanks in advance.
check to make sure your starter it hooked up properly or the screws are all tight, if its loose it can make whiny noises. If that is still not the case, then replace it with a new starter, also check your ground make sure its bolted down, and the small cable that connects to the starter. Those and let me know how it goes.
You may have issues with the PCM Valve. Check your electrical bro, it is not as harmless as we all think it is. Other than that it sounds like it is most likely your starter but get professional(a trusted local shop) advice and see how to fix the problem.
i just drove the car in so i'ma wait til everything cools down b4 i check it. But will def take it to a shop. If you guys have any more suggestions let me know thanks!
gobblebox59
Sep 4, 2004 09:05 AM
we'll see going to show this guy the car tomorrow.
