how hard to install/hookup 98 civic vtec engine?
hey i have a chance to buy a 98 vtec engine with 60k on it. the only reason i cant buy it is that i dotn know how to wire the vtec to work but i am geussing the rest just bolts in and slight wiring.if you could possibly help me i would appreciate it.THANKS!
What kind of car will you be installing it into? Assuming you already have MPFI its not too terrible. Go to http://www.rywire.com/ and look for the harness for your car. Then you'll need a new ECU too and some other little things. Here's an article to get you started http://crx.honda-perf.org/arti....html And by all means do a SEARCH
i own a 1990 civic si with d16a6 so yes i already have mpfi.i will be gettign the ecu too so no need to worry just dont wanna do the swap and
then be with out a car cause my **** dont run .
Check this out https://honda-tech.com/zerothread?id=554053
ya bu that pertains to 92-95 which coem equipped with hydro trans and obviuosly mien isnt.so if you can find soem more info for me i would appreciate the help thanks!
Nisif
Honda Civic (2001 - 2005)
Apr 30, 2024 08:03 PM
kkwick
16
Oct 6, 2020 11:46 AM
Josh1999Civic
Aug 14, 2015 02:44 PM
Civic#
Jun 17, 2014 02:11 PM
