APEX'i n-1 exhaust into eg hatch question..
Old Oct 10, 2005 | 09:22 PM
slowslow's Avatar
Default APEX'i n-1 exhaust into eg hatch question..
i just bought apexi's n-1 catback today (ex trim) for my 93 vx hatch. it has a jdm b16a2 with stock header. the cat isn't long enough to bolt up directly to the header. is this a common problem, do i need to take it to a muffler shop of should i take it back and get a differen't trim? thanks.
Old Oct 10, 2005 | 09:40 PM
shyboi4u's Avatar
Default Re: APEX'i n-1 exhaust into eg hatch question.. (living legend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by living legend &raquo;</TD></TR><TR><TD CLASS="quote">i just bought apexi's n-1 catback today (ex trim) for my 93 vx hatch. it has a jdm b16a2 with stock header. the cat isn't long enough to bolt up directly to the header. is this a common problem, do i need to take it to a muffler shop of should i take it back and get a differen't trim? thanks.</TD></TR></TABLE>
what do you mean by ex trim? i know someone that has an apexi n1 on there EG. they did a gsr motor and it was short to by like 7 inches i believe. take it to a muffler shop. have them custom fit you a cat.
Old Oct 10, 2005 | 09:58 PM
slowslow's Avatar
does anyone know what size the cat or test pipe should be? i don't feel like putting it together and then having to take it right apart again for the measurements!
Old Oct 10, 2005 | 10:00 PM
shyboi4u's Avatar
Default Re: (living legend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by living legend &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know what size the cat or test pipe should be? i don't feel like putting it together and then having to take it right apart again for the measurements!</TD></TR></TABLE>
get the omni test pipe. its adjustable.
Old Oct 10, 2005 | 10:25 PM
slowslow's Avatar
eh, wish i knew the size :[
Old Oct 10, 2005 | 10:30 PM
spreng87's Avatar
Well I got a catback for a dx/si hatchback trim and mine is a VX also and used a 94-01 cat with the 94-01 header for my LS and it was a perfect fit.
Old Oct 10, 2005 | 10:33 PM
GetawayInMoscow's Avatar
Default Re: APEX'i n-1 exhaust into eg hatch question.. (spreng87)
Obviously if you have an exhaust for a coupe on your hatch you will have problems. I would try getting a cat for a coupe. Just get a resonated test pipe off ebay for $30, that way if it doesn't fit you can sell it to some ricer and it won't break the bank.
Old Oct 11, 2005 | 06:06 AM
slowslow's Avatar
thanks guys!!
Old Oct 11, 2005 | 12:25 PM
slowslow's Avatar
anyone know the length of the coupe cat?
Old Oct 11, 2005 | 01:14 PM
slowslow's Avatar
anyooooooone?
Old Oct 11, 2005 | 01:57 PM
eg1point8's Avatar
get a usdm 00 si header itll work fine
Old Oct 11, 2005 | 11:57 PM
slowslow's Avatar
Default Re: (eg1point8)
i don't have a cat, so i need to find out the coupe cats length so i can make a testpipe
civic_freak
Jun 12, 2005 12:36 PM
SD_EM1
Jan 25, 2004 05:20 PM
EgSick
17
Apr 22, 2003 04:26 PM
Aaron M
Feb 12, 2003 04:47 AM
