gauge cluster
ok i finally found out why my vtec is not working in my car. For some reason the gauge cluster went bad which caused sporadic vtec engagement. but now my tachometer, fuel meter and temp gauge is not working after i installed the new cluster. So my question is what are the wiring differences for the 1988 crx DX,HF and SI. in the cluster?
Modified by tallguy at 3:08 PM 10/10/2005
tach, fuel guage, and temp all plug into the same fuse(bottom row in the middle 10 amp) as your turn signals.
First check your turn signal wires and make sure none of them are grounding that's what mine was doing. Second replace the fuse.
vmm
Apr 18, 2005 04:05 PM
hondasleeper
10
Sep 20, 2004 08:45 AM
SnowSurfer
Jun 20, 2004 08:08 AM
