can somebody help identify this part
Old Oct 10, 2005 | 11:49 AM
ntm's Avatar
ntm
Default can somebody help identify this part
as i was driving my gas pedal went flat and wouldn't accelerate when i pushed on it. i pulled over to find that the the piece holding the throttle cable was broken and fell off. i have no idea what the piece is called. it is the piece on the top right of the picture (the gold thing) it fell off and i am assuming something broke. at the end of it it looks like a bolt with nothing holding the piece on. i am sorry for the bad description..
here is a pic...(not mine, sorry for stealing it if it belongs to you..)
Old Oct 10, 2005 | 11:58 AM
beaneg6's Avatar
Default Re: can somebody help identify this part (ntm)
check your throttle cable bracket or even your gas pedal underneath your dash...maybe it just wiggled its way out of there
Modified by beaneg6 at 1:10 PM 10/10/2005
Old Oct 10, 2005 | 12:04 PM
JDMlyfestyle's Avatar
prolly broke your throttle cable bracket. if there is too much tension on them it can break them or if the bolts were loose.
Old Oct 10, 2005 | 01:03 PM
TeamNextGenChris's Avatar
that's the throttle rotor.did you lose the piece when it came off?
BTW-did anybody actually read the post?!
Chris
Old Oct 10, 2005 | 01:16 PM
ntm's Avatar
ntm
Default Re: can somebody help identify this part (TeamNextGenChris)
the throttle rotor is the gold piece right? if it is, then it is still there but it came off of the bolt that it was on. i am assuming that there was another piece on the bolt that must have falllen off or broken? but not sure what itis called.
Old Oct 10, 2005 | 01:26 PM
ntm's Avatar
ntm
found this picture.....
it is the piece in the middle throttle rotor that broke off (like the tip of it). any idea what that is called or part # ? thanks
Old Oct 10, 2005 | 01:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntm &raquo;</TD></TR><TR><TD CLASS="quote">found this picture.....
it is the piece in the middle throttle rotor that broke off (like the tip of it). any idea what that is called or part # ? thanks</TD></TR></TABLE>
it's held on by a nut and lock washer.that's what came off and allowed the rotor to fall off.
Chris
Old Oct 10, 2005 | 01:49 PM
hatchi's Avatar
Throttle Rotor
truxvi3tz
Mar 31, 2010 02:26 PM
Tu MaDre
Honda Civic (2001 - 2005)
Oct 30, 2007 09:32 AM
B18C Turbo
Oct 18, 2006 12:50 PM
RA61825
Feb 14, 2005 10:04 AM
return_2020
Dec 8, 2004 02:38 PM
