oil pan problem
Old Oct 10, 2005 | 08:40 AM
y0itzflip's Avatar
Default oil pan problem
man i just changed my oil like usualy, but i never changed the washer b4. well now i got a small leak, well its big to me cuz in a few hours all oil was gone. i have narrowed it down to where the bolt is...i went to discount auto and got a bolt washer replacement but same thing. do u think if i go get a honda part it will make a difference? or could it be somethin else..there are no cracks in the pan and i had no leaks b4 this change...
Old Oct 10, 2005 | 11:06 AM
notoriousB's Avatar
Default Re: oil pan problem (y0itzflip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y0itzflip &raquo;</TD></TR><TR><TD CLASS="quote"> well now i got a small leak, well its big to me cuz in a few hours all oil was gone.</TD></TR></TABLE>
uh, yeah, that's a BIG leak. where is it leaking from? having a used washer on there will not cause all the oil to drain out.
Old Oct 10, 2005 | 11:32 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Take a look a the drain bolt, are all the threads okay? What about the threads in the oil pan?
See if a new drain plug bolt will stop the leak, it may have better threads on the new bolt.
Old Oct 10, 2005 | 01:40 PM
HondaTechPro's Avatar
Default Re: oil pan problem (tech8)
Generally a drain plug washer will not cause ALL of the oil to leak out, and certainly not in a short amount of time. I suspect that like tech8 said, the oil pan may be stripped out, preventing you from tightening the plug enough to get the washer to seal.
Old Oct 10, 2005 | 02:07 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: oil pan problem (HondaTechPro)
Doubt a washer could do that. But a washer should be used everytime you change the filter
Old Oct 10, 2005 | 05:36 PM
jfish's Avatar
Default Re: oil pan problem (Vt4cPwn35)
May be a hairline crack where the plug is
Old Oct 10, 2005 | 08:58 PM
deserthonda's Avatar
most likely the threads on the pan are stripped ,, remove the plug and look at the threads
Old Oct 10, 2005 | 09:18 PM
y0itzflip's Avatar
Default Re: oil pan problem (jfish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfish &raquo;</TD></TR><TR><TD CLASS="quote">May be a hairline crack where the plug is</TD></TR></TABLE>
exactly that got to look at it in the hot *** miami sun today and thats what i saw...this sucks...any1 got an oil pan?
Old Oct 11, 2005 | 05:12 AM
u dont need to replace the pan,, se if a shop down there has an oil oan olug kit,, it comes with an insert. they drill the pan to a bigger size hole, install the insert and a new plug we do a **** load in my shop it works very very good ..save money on a pan, pan gasket , and a lot of more work ..,,if u do job urself,,Matco tools sells the kit ...
sleeperhonda
10
Aug 20, 2013 08:18 AM
ombl4
May 10, 2007 01:42 PM
93(Civic)EG6
Nov 3, 2006 02:25 PM
MechEng
Oct 21, 2005 12:14 PM
teewhy55
13
Dec 13, 2004 11:17 AM
