idle surge problem after flywheel installation
Old Mar 4, 2002 | 07:20 PM
rice4life's Avatar
Default idle surge problem after flywheel installation
my friend has an 89 civic si and he just install clutch master aluminum flywheel and now the car has a surging idle problem. does any have the same problem and what did you do to fix it?
Old Mar 5, 2002 | 06:41 AM
Spade's Avatar
Default Re: idle surge problem after flywheel installation (rice4life)
It may just be dumb luck that the IACV went bad, try adjusting the idle a little higher and see if that fixes it.
Old Mar 5, 2002 | 07:29 AM
rainforest's Avatar
Default Re: idle surge problem after flywheel installation (Spade)
you knocked out a vacume line. just double check.
Old Mar 5, 2002 | 03:39 PM
rice4life's Avatar
Default Re: idle surge problem after flywheel installation (rainforest)
so it has nothing to do with the fact that the flywheel is so light. i thought it was a vacume line too
jarven093
May 16, 2007 10:29 AM
TeknoJunki
14
Aug 10, 2004 10:05 AM
petrv
Sep 25, 2003 06:11 AM
rice4life
Mar 4, 2002 08:52 PM
rice4life
Mar 4, 2002 07:50 PM
