98 civic ex converted to B20 vtec wiring harness???
Old Oct 9, 2005 | 05:08 PM
a_obermoller's Avatar
Default 98 civic ex converted to B20 vtec wiring harness???
ive got a 98 civic ex i bought a motor that was supposed to be done its a b20b4 block with a 99-00 civic si head i need to figure out if i can use my old ex wiring harness i need one with a crank angle sensor because i have a b20 crank angle sensor on the block. do the crank angle sensors off the ex harnees the same plug as a b18 b16 b20? or are d series different is anyhting else different or do i just need to get s 99-00 si engine harness?
Old Oct 9, 2005 | 05:18 PM
ek-to-tha-max's Avatar
no, use your EX harness. you dont need the crank sensor
Old Oct 9, 2005 | 05:39 PM
97civicdx's Avatar
Default Re: (ek-to-tha-max)
Dont you need that CKF sensor for the obd2 ecu?
IDriveHonda
14
Jul 31, 2018 09:52 AM
dsol
Aug 2, 2016 11:02 AM
Punker1234
Apr 21, 2005 02:46 PM
colt45.5
Jan 6, 2004 02:41 PM
