Car shakes when driving... rotors?
Old Oct 9, 2005 | 11:53 AM
T--Rex's Avatar
Default Car shakes when driving... rotors?
If I drive at any speed, the car sort of wobbles back and forth a little, and the steering wheel shakes back and forth a little. It is more annoying when on the freeway because it shakes alot faster. When i hit the brakes hard it becomes alot worse. Could this be the rotors? or what else could be causing this?
Old Oct 9, 2005 | 12:04 PM
SiR Inspired ED7's Avatar
Default Re: Car shakes when driving... rotors? (T--Rex)
alignment?
Old Oct 9, 2005 | 12:43 PM
NACvicSi's Avatar
Default Re: Car shakes when driving... rotors? (88 Crx Si)
I have heard a couple of people complain about this. Turned out their lug nuts weren't tightened.
Old Oct 9, 2005 | 12:52 PM
OverCorrupt's Avatar
i had this complaint.. was sooo bad i thought it was my axle bent.. but all it ended up being was a simple balance got rid of everything
Old Oct 9, 2005 | 01:40 PM
RCautoworks's Avatar
Default Re: (OverCorrupt)
Check the tires, they might need to be balanced.
Does the shaking get worse when you brake ? Does your brake pedal pulse, if not, that should rule out the rotors.
Old Oct 9, 2005 | 07:54 PM
T--Rex's Avatar
Default Re: (90blackcrx)
It will shake even at 5 mph, but it is just more noticible at faster speeds. When i put on the breakes on the freeway it shakes harder.
Old Oct 9, 2005 | 07:58 PM
Default Re: (T--Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T--Rex &raquo;</TD></TR><TR><TD CLASS="quote">It will shake even at 5 mph, but it is just more noticible at faster speeds. When i put on the breakes on the freeway it shakes harder. </TD></TR></TABLE>
Does the brake pedal pulsate at all ?
Old Oct 11, 2005 | 05:08 PM
StorminMatt's Avatar
If you have vibration AND brake pedal pulsation, then you could have a bent hub.
Old Oct 11, 2005 | 06:40 PM
Autoworks's Avatar
Default Re: (StorminMatt)
You could have several sceneraios.
It is possible to have an extremely warped rotor that will cause a pulsation even when not braking. Usually a side to side steering wheel shake whil breaking is do to a warped rotor.
You can have, like I had, a CV shaft with bad bearings. Mine wer both new, but I would get a shake under hard acceleration, turned out to be one of my shafts, which I just pulled out and warrantied.
Low speed shake like your car is taking lazy side to side walking steps=seperated tires, it gets worse as you speed up.
You could have an out of balance wheel, but you usually won't feel that at a low speed. It is very possible to not have your wheel sitting flush on the hub or using the wrong lug nuts which both will cause your car to ride like ****.
It's not the alignment (the pulsation)
I run a wheel and tire shop, most people with 20"s and up come in saying "my car is shaking, does that mean I need an alignment (actually most say line up) the answer is always no, its always something else.
Modified by Autoworks at 3:54 AM 10/12/2005
Old Oct 11, 2005 | 06:49 PM
CantThinkOfAScreenName's Avatar
Default Re: (Autoworks)
If your rotors are warped you would have a pulsation from your brake pedal.....Check your rims you might have thrown a weight, or you could have tread seperation...and last but not least check your bearings.....
Old Oct 11, 2005 | 07:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">If you have vibration AND brake pedal pulsation, then you could have a bent hub.</TD></TR></TABLE>
Same symptoms of a warped rotor.
Old Oct 11, 2005 | 08:44 PM
TommyBB's Avatar
go get your tired balenced.. or have them check the balanced. I see that alot.
Old Oct 11, 2005 | 09:36 PM
ijustchillin's Avatar
I used to have the same problem as you. Vibration at low speeds and get worse as you go faster right? I checked everything everyone posted above and found nothing wrong. I then decided to get new tires all around and it fixed everything.
I was looking at the old tires as the mechanic was rolling it away and I noticed that the inside walls were warped, crappy *** kumhos. If you don't have the money to get new tires I suggest you take it to a tire shop and ask them to balance all 4 tires.
Old Oct 11, 2005 | 11:46 PM
Lamchop0000's Avatar
also... checek if the steering rack is still still nice and tight, and the bushings arn't worned out.
Old Oct 12, 2005 | 04:35 AM
crx_88_si's Avatar
Default Re: Car shakes when driving... rotors? (LamRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LamRacing &raquo;</TD></TR><TR><TD CLASS="quote">also... checek if the steering rack is still still nice and tight, and the bushings arn't worned out.</TD></TR></TABLE>
Do a search on "Steering rack end bushing"
common thing apparently. wheel shakes side to side while driving, shakes hard under highway 40mph&gt; speeds but the pedal is not pulsating.
Old Oct 12, 2005 | 05:11 AM
Autoworks's Avatar
Default Re: Car shakes when driving... rotors? (crx_88_si)
Just go run your hands over and around your tires looking for seperation. (ridges, bumps, slopes)
Old Oct 21, 2005 | 04:41 PM
T--Rex's Avatar
Default Re: Car shakes when driving... rotors? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">Just go run your hands over and around your tires looking for seperation. (ridges, bumps, slopes)</TD></TR></TABLE> Tires are pretty low.... also the pettel doesn't pulsate when i press the brake, however when i give the car alot of gas or brake hard the steering wheel shakes more.
Old Oct 21, 2005 | 05:06 PM
Tyson's Avatar
your steering rack END bushing needs replacement. $10 part.
https://honda-tech.com/zerothread?id=1117870
also, check your tie rod end and inner balljoints for play.
dont forget to tighten your pinion gearbox.
trust me, i had this problem on BOTH CRX ive owned and done it on other ppls car, all with the same symptoms and great results.
it MAY be your rotors being warped, but warped rotors should not cause your car to vibrate and shake. a warped rotor alone will just be a mild pulsing.
Old Oct 22, 2005 | 04:24 AM
Default Re: Car shakes when driving... rotors? (Tyson)
Also check on your front wheel bearings. Make sure they are tight. I had a HORRIBLE vibration problem due to this. And simply tightning the axle nut took care of it. However, if the axle night is tight and the front wheel bearing is STILL loose, then you need to replace the bearing.
Old Oct 22, 2005 | 05:27 PM
JoEyHaTcH91's Avatar
most likely its the rotors. but it also could be the allignment and the wheel balancing
pokmijn
Nov 29, 2007 05:09 PM
vart
21
Jul 17, 2006 01:25 PM
Devo94ac
Jan 31, 2006 08:52 PM
dcb284
May 19, 2005 06:51 AM
gsr-2nr
Apr 29, 2004 01:33 PM
