FS: Benson Sleeved Gsr motor bare, tranny, head, Arp, from a 00
Old Oct 9, 2005 | 10:46 AM
u2civic1's Avatar
Default FS: Benson Sleeved Gsr motor bare, tranny, head, Arp, from a 00
everything here is off a 2000 gsr swap i have paper work for it and all
has about 40 k on everything and the sleeves have been only 10k
the block has 83mm Benson sleeves it comes with mains but no crank.
only one oil squiter was welded shut so you will have to shut the other three with bolts https://honda-tech.com/zerothread?id=1081578 or get the other three welded btw u don't need oil squirter if u are running forged pistons
the tranny works fine no grinds or pop outs or anything
head comes with the gsr cams with skunk 2 cam gears
also have
ARP
one axle and half axle
obd2a and obd2b ecu
alternator and power steering
tb
intake manifold
linkage
crank pulley
gsr(same as type r) oil pump and water pump
starter
six puck clutch specialist and flywheel
sensors
all u need are some forged pistons, crank, and rods and your good for 500+hp
located in CA
orange county area
looking to get around 2100 to 2300 depending on what u want
this is almost a complete swap just spend a extra 1000 for pistons crank and rods and it would be the same cost as a stock gsr swap and this is a 2000 motor and only has 40k on it
make some offers that i can't refuse
no trades right now
im willing to part if necessary
Modified by u2civic1 at 12:02 PM 10/9/2005
Old Oct 9, 2005 | 04:16 PM
u2civic1's Avatar
Default Re: FS: Benson Sleeved Gsr motor bare, tranny, head, Arp, from a 00 (u2civic1)
5:16
Old Oct 10, 2005 | 10:53 AM
u2civic1's Avatar
11:52 bump
Old Oct 10, 2005 | 05:45 PM
u2civic1's Avatar
6:44 bump
Old Oct 11, 2005 | 03:23 PM
u2civic1's Avatar
4:22 bump
Old Oct 11, 2005 | 05:45 PM
socaly4life's Avatar
Are the ARP's the ones that you thread into the block?
Old Oct 12, 2005 | 05:52 PM
u2civic1's Avatar
Default Re: (socaly4life)
6:53 bump
Old Oct 13, 2005 | 06:20 AM
u2civic1's Avatar
Default Re: (u2civic1)
7:19 bump
Old Oct 13, 2005 | 02:05 PM
u2civic1's Avatar
3:05
Old Oct 13, 2005 | 07:45 PM
u2civic1's Avatar
8:45 bump
Old Oct 14, 2005 | 11:05 AM
u2civic1's Avatar
12:05 bump
Old Oct 14, 2005 | 06:17 PM
u2civic1's Avatar
sale pending on the gsr tranny
Old Oct 16, 2005 | 04:14 PM
u2civic1's Avatar
5:13 bump
integradude18
Aug 2, 2011 05:57 PM
integradude18
Jul 22, 2011 09:13 AM
u2civic1
Nov 2, 2005 09:32 PM
u2civic1
Oct 20, 2005 09:19 PM
u2civic1
Oct 7, 2005 07:45 PM
