short ram vs DIY ice box
Old Mar 4, 2002 | 05:24 PM
JMX's Avatar
JMX
Default short ram vs DIY ice box
hey i have a short ram intake right now ..left over from the hatch. but im thinking are they any better or worse than the DIY ice box. if it is well hell ill put it back on
any dyno's on this or personal thoughts
Old Mar 5, 2002 | 06:15 AM
JMX's Avatar
JMX
Default Re: short ram vs DIY ice box (jmx2323)
damn it pretty cool how i never get a response in the tech forum
Old Mar 5, 2002 | 06:46 AM
SoloSol's Avatar
You would only see a few hp if that. So It's up to you. The gain that you could get you will probably not even notice.
Old Mar 5, 2002 | 08:33 AM
JMX's Avatar
JMX
Default Re: short ram vs DIY ice box (SoloSol)
so really there is no difference ??
if so thats cool less work for me
Old Mar 5, 2002 | 09:01 AM
bps2799's Avatar
A DIY should be better, since you can route COLD air from outside into the intake, as opposed to the short ram, which is breathing underhood air, which should be quite warm (HOT).
I made a DIY using stock air cleaner box, heater hose ran outside the underhood compartment, no resonator (good riddance), and a K&N filter.
Ask on the integra forums too.
Old Mar 5, 2002 | 10:39 AM
BSQ's Avatar
BSQ
Default Re: short ram vs DIY ice box (bps2799)
The DIY "Icebox" will give you much better throttle response and the low to mid range power will also be better. I highly recommend the DIY "Icebox".
You can go to my webpage at http://www.geocities.com/bretq/DIY_Icebox_CAI.html for instructions on making your own "Icebox".
BTW, I also just started selling my Icetake CAI which will save you from having to find the material for making your own "Icebox". Go to http://www.geocities.com/bretq/icetake_cai.html for further information. You can also check out the classified forum at https://honda-tech.com/zerothread?id=140106
doubleoazn03
Jun 6, 2009 04:09 PM
huckduck
May 30, 2008 03:10 PM
Tony C
May 19, 2004 11:45 AM
Crackerballer
Dec 23, 2003 11:10 AM
csfalcon
Aug 18, 2002 08:54 AM
