burning oil & good compression
Old Oct 9, 2005 | 07:37 AM
red teg's Avatar
Default burning oil & good compression
burning oil & good compression is it possible that the the piston oil rings can go
bad but the compression rings stay fine mine is about 230 psi on all 4
the problem is my car is using 1 litre of oil in 500 miles the cylinder head was rebuilt 12 months ago so the valve seals should be good
Old Oct 9, 2005 | 08:46 AM
s2kdre's Avatar
Default Re: burning oil & good compression (red teg)
u can have prefect compression numbers and have bad rings. As long as it doesnt smoke on cold start ups, then its not valve seals.
Old Oct 9, 2005 | 01:08 PM
nuckingfuts's Avatar
Default Re: burning oil & good compression (Racebred H)
most likely your oil control rings are shot, or you have bad valve seals... or you are leaking a ton of oil somewhere (but i'm sure you would notice that).
to be sure if it is infact your rings or valve seals you should also do a leak down test. what were your compression numbers?
usually the car will smoke when you first start it up if the valve seals are bad. easier to replace than the rings of course.
only way to be sure is do leakdown test.
Old Oct 9, 2005 | 01:45 PM
Booker's Avatar
Banned Duplicate Account
Default Re: burning oil & good compression (nuckingfuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuckingfuts &raquo;</TD></TR><TR><TD CLASS="quote"> what were your compression numbers?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red teg &raquo;</TD></TR><TR><TD CLASS="quote"> mine is about 230 psi on all 4</TD></TR></TABLE>
Old Oct 9, 2005 | 03:33 PM
Default Re: burning oil & good compression (Booker)
thanks
alchemyst6
18
Jul 21, 2011 10:08 AM
mike93eh
21
Sep 18, 2005 12:23 PM
xlusiveracer
Sep 7, 2005 04:13 PM
DANG YO
Nov 24, 2003 04:26 AM
