D16Y8 head on a D16Z6 block. What head bolts do i use?
Old Oct 9, 2005 | 06:23 AM
vtec25's Avatar
Default D16Y8 head on a D16Z6 block. What head bolts do i use?
i emailed ARP and they gave me the specs for the bolts since they differ in size here are the specs:
D16Y8 Head Stud Kit 208-4305
10mm by 5.700” studs (qty10)
D16Z6 Head Stud Kit 208-4301
10mm by 6.450” studs (qty 10)
So which ones should i buy?? Someone here has to know and/or have a Y8 head on Z6 block.
Please help
Old Oct 9, 2005 | 05:13 PM
vtec25's Avatar
Default Re: D16Y8 head on a D16Z6 block. What head bolts do i use? (vtec25)
BUMP
Old Oct 9, 2005 | 06:31 PM
drevinder's Avatar
y8 head = y8 head bolts
z6 head = z6 head bolts
i think they might be same....bump for u
Old Oct 9, 2005 | 06:34 PM
EK k kay's Avatar
Default Re: D16Y8 head on a D16Z6 block. What head bolts do i use? (drevinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder &raquo;</TD></TR><TR><TD CLASS="quote">y8 head = y8 head bolts
i think they might be same....bump for u </TD></TR></TABLE>
I swore your bro told me the opposite: use the bolts that correspond to the block you're using...
btw. me = chowmien if ya didn't notice the name change
Old Oct 16, 2005 | 05:03 PM
dohdoh420's Avatar
Default Re: D16Y8 head on a D16Z6 block. What head bolts do i use? (EK k kay)
I am also wondering the same, but I'm gonna be using a z6 head on y8 block.. also what timeing belt, and or cam/cam gear do I use?
Old Oct 20, 2005 | 12:24 PM
viskii420's Avatar
bump... wondering the same... got y7 block.. with d16z6 head.. wat problem am i gona expect.. and what do i need to solve them
Old Oct 20, 2005 | 01:32 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Kind of off-topic since I have no clue what bolts to use, but why are you using a Y8 head instead of a Z6 head?
Y8 may raise CR, but it doesn't flow as well.
Old Oct 20, 2005 | 01:44 PM
HiProfile's Avatar
Default Re: D16Y8 head on a D16Z6 block. What head bolts do i use? (B18C5-EH2)
Z6 studs are a bit longer than Y8 studs.
I know for sure that with a Y8 BLOCK and a Z6 HEAD you need the Y8 studs plus a Z6 stud (got mine for a bit extra with a kit from lightningmotorsports). I'm assuming that the Z6 block has all threads (besides that one corner) sunk in a bit deeper than a Y8 block. If that's the case, I'd want to suggest Z6 studs (and possibly 1 short y8 stud).
<U>My advice would be to test out with old Z6 bolts (6.450" long) and if none bottom out, get the Z6 stud kit.</U>
Old Oct 20, 2005 | 03:56 PM
viskii420's Avatar
for high compression.. maybe.. z6 is for turbo app.. low compression
Old Oct 20, 2005 | 04:27 PM
peiku's Avatar
Default Re: (viskii420)
use 9 z6 studs and 1 y8 stud with that head/block combo. its the other way around fo rhte z6 head/y8 block combo (9 y8 studs and 1 z6 stud).
Old Oct 20, 2005 | 05:01 PM
vtec25's Avatar
Default Re: (peiku)
"use 9 z6 studs and 1 y8 stud with that head/block combo. its the other way around fo rhte z6 head/y8 block combo (9 y8 studs and 1 z6 stud). "
Ok Do you know where to use that 1 y8 stud???
and i'm useing the y8 head but its ported and polished, 3 angle valve job, etc.
Old Oct 21, 2005 | 05:49 AM
HiProfile's Avatar
Default Re: (vtec25)
Its the bolt on the rear passenger or front driver corner - I can't recall offhand. When I get home I'll double check my z6 head and let you know. BTW, once my stud kit gets here, I'll have a spare y8 stud... PM if interested
Old Oct 22, 2005 | 05:29 AM
peiku's Avatar
Default Re: (HiProfile)
its the very first hole on the top left, by the vtec solinoid. use the y8 stud on that spot. my cousin put a y7 head on his 92 dx block (all 88-95 civics use the same bolts and studs) so i know what i am talking about. you can try to use a y8 stud but it will be really short, like barely sticking out of the hole short. my cousin needed the car running so he just used the dx bolt with alot of washers. hey it worked but i wouldnt have done it though.
Old Oct 22, 2005 | 07:12 AM
mike93eh
Guest
Posts: n/a
i have a y8 head on a z6 block and im using z6 studs. i just had to put an extra washer on two of the studs, no big deal.
Old Oct 22, 2005 | 02:35 PM
peiku's Avatar
Default Re: (mike93eh)
no big deal but i would not recommend doing that on a boosted setup though.
Old Oct 22, 2005 | 02:41 PM
mike93eh
Guest
Posts: n/a
Default Re: (peiku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">no big deal but i would not recommend doing that on a boosted setup though.</TD></TR></TABLE>
oh and why not?? my car is boosted, has been for awhile. no problems here. seriously what is one extra washer going to hurt. shut up.
Old Oct 22, 2005 | 06:59 PM
peiku's Avatar
well it will hurt when you blow your motor. i hope that washer is from arp and not one from the hardware store. different metals expand at different temps. and no need for the harsh words. we're all single cam guys here.
Old Oct 22, 2005 | 07:28 PM
mike93eh
Guest
Posts: n/a
Default Re: (peiku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">well it will hurt when you blow your motor. i hope that washer is from arp and not one from the hardware store. different metals expand at different temps. and no need for the harsh words. we're all single cam guys here.</TD></TR></TABLE>
its not arp but just the same. i couldnt believe my hardware store had it. anyways i have been running just fine with the extra washer so right then and there you know it is a proven fact that it is alright and wont hurt anything.
Old Oct 22, 2005 | 07:37 PM
HiProfile's Avatar
ARP bolts are on a COMPLETELY different scale as any hardware bolt. First off, they aren't as brittle as grade 5 or grade 8 bolts are - yet they are much stronger. Think about it, they're bolt sets that cost ~$8-10 per stud/nut when in a kit, and that's below retail value. Hardware stores wouldn't charge $5 per bolt like that to stay competitive with other stores.
I don't think it will allow noticable head lifting, but there's a good chance that it will eventually warp the head.
Old Oct 22, 2005 | 07:42 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">ARP bolts are on a COMPLETELY different scale as any hardware bolt. First off, they aren't as brittle as grade 5 or grade 8 bolts are - yet they are much stronger. Think about it, they're bolt sets that cost ~$8-10 per stud/nut when in a kit, and that's below retail value. Hardware stores wouldn't charge $5 per bolt like that to stay competitive with other stores.
I don't think it will allow noticable head lifting, but there's a good chance that it will eventually warp the head. </TD></TR></TABLE>
they have tons of expensive *** hardware and no i will not be warping my head.
eg6civic1538
Feb 23, 2009 08:27 AM
Manny86
May 22, 2007 10:17 AM
Eyal 951
Sep 16, 2006 10:42 PM
jdmstreethatch
Aug 17, 2005 08:01 AM
