ecu question
Old Oct 9, 2005 | 05:13 AM
eg_gsr11's Avatar
Default ecu question
i have a b18c1 in my 92 coupe with an msd ing. im not geting a spark and my fuel pump isnt turning on. i think i might have shorted my ecu. what do you guys think?
Old Oct 9, 2005 | 06:47 AM
TeamNextGenChris's Avatar
Default Re: ecu question (eg_gsr11)
does the check engine light come on for a few seconds when you turn the key on?
can you hear the main relay click on and off when you turn the key on?
when you short the ECU jumper,does the CEL flash any codes or come on at all with the key on?
did the car run fine until the MSD install?
chris
Old Oct 9, 2005 | 08:07 PM
eg_gsr11's Avatar
Default Re: ecu question (TeamNextGenChris)
ok it ran fine with the msd install, drove it for the first time, about 150 miles straight and it was fine. pulled into the drive way and it would just crank over but not start. i didnt think to check the relay, and i get a solid CEL that doesnt turn off. i didnt check the CEL codes i will do that and then get back to you. thank you for the help
arrocha87
20
May 13, 2009 03:46 PM
tanzoid
Jan 4, 2007 03:50 AM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
01IntegraSE
Mar 20, 2003 05:56 PM
