ecu question
ecu question
i have a b18c1 in my 92 coupe with an msd ing. im not geting a spark and my fuel pump isnt turning on. i think i might have shorted my ecu. what do you guys think?
1 Post
Re: ecu question (eg_gsr11)
does the check engine light come on for a few seconds when you turn the key on?
can you hear the main relay click on and off when you turn the key on?
when you short the ECU jumper,does the CEL flash any codes or come on at all with the key on?
did the car run fine until the MSD install?
chris
chris
Re: ecu question (TeamNextGenChris)
ok it ran fine with the msd install, drove it for the first time, about 150 miles straight and it was fine. pulled into the drive way and it would just crank over but not start. i didnt think to check the relay, and i get a solid CEL that doesnt turn off. i didnt check the CEL codes i will do that and then get back to you. thank you for the help
mkw1
07-19-2008 09:58 AM
tanzoid
01-04-2007 03:50 AM
BOOSTEDgreeneg
09-15-2005 07:27 PM
