cell code 3???
Old Oct 8, 2005 | 08:54 PM
TheIceMan's Avatar
Default cell code 3???
check engine light....i checked code....3 short blinks.....what is this??
Old Oct 8, 2005 | 09:00 PM
sparco562's Avatar
Default Re: cell code 3??? (SigleyEK)
https://honda-tech.com/zerothread?id=1171263
.Beaver's Avatar
Bloody Beaver
you could have just read the Code thread stickied at the top of the forum...
MAP sensor!
Old Oct 8, 2005 | 09:03 PM
TheIceMan's Avatar
what does the map sensor have to do with me loosing vtec.....check engine light comes on and vtec will not engage...im getting a map sensor code though?
Old Oct 8, 2005 | 09:11 PM
xXx Justin xXx's Avatar
Default Re: (SigleyEK)
check your main wire for the vtec solinoid. be sure it has a solid connection all the way through. My old 94 turbo hatch would give me a MAP CEL, changed it, no luck, put it back on the dyno... when it showed up 24whp less we started testing for things, found vtec had a lose connection.
sodered the wire for good connection, CEL went away, got the power back.
Old Oct 8, 2005 | 09:26 PM
TheIceMan's Avatar
all my wires are solid...had it checked profesionaly and one wire seemed to be loose which was sottered...but as of loose connections everything seems to me tight...my fear is getting a new map sensor and i will still get that code...BTW...i do not have an O2 sensor hooked up
Groove_D
May 27, 2006 11:40 AM
IVI
Aug 26, 2004 01:04 PM
gokuson
Mar 18, 2003 07:27 PM
GTEater
Aug 23, 2001 06:23 PM
