closed loop/open loop ECU and piggyback comp
Old Mar 4, 2002 | 04:29 PM
ckkl's Avatar
Default closed loop/open loop ECU and piggyback comp
Hi all,
I was wondering -- if piggybacks (e.g. VAFC) alter 02 sensor input signals to get different output signals, how does that react under closed/open loop? It sounds like settings would only work for one case or the other....
Also, one more thing, can someone clarify for me: open loop means using 02 sensor (right? Since the ECU is "open" to environmental input) and closed loop means using raw fuel map values (i.e. not using 02 sensor, hence "closed" to the outside world)... is that right? I've heard otherwise....
Old Mar 4, 2002 | 06:00 PM
tinkerbell's Avatar
Default Re: closed loop/open loop ECU and piggyback comp (ckkl)
upside down - open is from ECU data
closed is from O2 input...
most piggy backs go for the MAP adjustment (which is the most influential ECU input to determine pulse width of injector duration and hence A/F ratio)
t..
Old Mar 5, 2002 | 04:02 AM
EE_Chris's Avatar
Default Re: closed loop/open loop ECU and piggyback comp (tinkerbell)
tinkerbell is correct: When the ECU is in Open Loop mode, it is using internal pre-programmed values to control injector PW. When the ECU is in Closed Loop mode, it is using the O2 sensor for trimming the PW to maintain good emmisions.
Also, the ECU mainly relies on MAP & RPM input to intially 'look-up' these values for injector PW...its then trimmed by other sensor inputs, such as ECT, IAT, etc.
Old Mar 9, 2002 | 07:32 PM
ckkl's Avatar
Default Re: closed loop/open loop ECU and piggyback comp (EE_Chris)
<Also, the ECU mainly relies on MAP & RPM input to intially 'look-up' these values for injector PW...its then trimmed by other sensor inputs, such as ECT, IAT, etc.>
What's ECT and IAT?
Old Mar 10, 2002 | 03:44 AM
B18C-EJ1
Guest
Posts: n/a
What's ECT and IAT?
ECT - Engine Coolant Temp
IAT - Intake Air Temp
[Modified by B18C-EJ1, 4:44 AM 3/10/2002]
planeman01
Mar 18, 2006 01:32 PM
JokerTypeR
Jul 13, 2005 05:15 PM
mrx
Mar 6, 2004 09:09 AM
