Suspension & Brakes Theory, alignment, spring rates....
Beaks ITR Rear Swaybar Kit on a EK???
Old Oct 8, 2005 | 01:42 PM
1clean00EM1's Avatar
Default Beaks ITR Rear Swaybar Kit on a EK???
Hi everyone, just curious about the beaks kit for the EK. I have heard its a great kit and will keep the swaybar from breaking off the car or may i say tearing off the car. But then i have heard the New Suspension Technique 19mm Rear Sway Bar, Part# 51145 is the best. Can anyone help me out, which one is better and most important safest?? thanks
Old Oct 8, 2005 | 10:11 PM
ekian's Avatar
Default Re: Beaks ITR Rear Swaybar Kit on a EK??? (98EK-R)
I am running the S/T 19mm. I also run the front bar. While I can't comment on the "safety" of the bar, because I've never had a subframe tear out, I can say that it is a great bar. I am no suspension expert but afaik, running a higher rate spring along with the sway bar will lessen the chances of subframe tear out. Of course, you could always get the ASR subframe brace with the provided sway and never have to worry about it. HTH.
Old Oct 11, 2005 | 08:17 AM
Default Re: Beaks ITR Rear Swaybar Kit on a EK??? (ekay.ian)
Well i just got the DC sports lower Tie bar, just want a good swaybar
Old Oct 11, 2005 | 10:31 AM
nonsense's Avatar
I have a Beaks kit on my EK (ok, so it's in the garage, I'll install it this week). I got it used and it came with a free chunk of subframe Looking at the chunk it looks like the thing came loose as the mounting holes are out of round. I also noticed that it had Grade 5 bolts!! I'll be installing it with some new Grade 8 bolts and I'll be checking it from time to time to make sure it's still torqued and to see if there's any wear on the subfram holes.
There have been a few tearouts with beaks, but there have also been a lot of people running the kit with no issues at all. -
Old Oct 11, 2005 | 11:02 AM
ek9vboi2's Avatar
Default Re: Beaks ITR Rear Swaybar Kit on a EK??? (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">I have a Beaks kit on my EK (ok, so it's in the garage, I'll install it this week). I got it used and it came with a free chunk of subframe Looking at the chunk it looks like the thing came loose as the mounting holes are out of round. I also noticed that it had Grade 5 bolts!! I'll be installing it with some new Grade 8 bolts and I'll be checking it from time to time to make sure it's still torqued and to see if there's any wear on the subfram holes.
There have been a few tearouts with beaks, but there have also been a lot of people running the kit with no issues at all. -</TD></TR></TABLE>
You might want to get some thread lock and some lock nuts so it wont back out.
I made my own custom kit (like beaks, but better). its made of steel and has a wide surface area so the pressure is distributed to a wider area.
btw i have a CTR rear sway bar (made for ek).
Old Oct 11, 2005 | 12:24 PM
nonsense's Avatar
Default Re: Beaks ITR Rear Swaybar Kit on a EK??? (ek9vboi2)
got any pics? I was looking into making something myself. How far away from the subframe did you space the sway bar?
Old Oct 11, 2005 | 12:32 PM
ek9vboi2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">got any pics? I was looking into making something myself. How far away from the subframe did you space the sway bar? </TD></TR></TABLE>
I'll snap some pictures or try to find some on my laptop/pc.
Old Oct 15, 2005 | 07:03 AM
get those pics up yet? thanks
Old Oct 16, 2005 | 02:49 PM
10secwantabe's Avatar
Check this out. This is The only way to be safe.
http://www.passwordjdm.com/pro...D=289
Old Oct 16, 2005 | 06:12 PM
Default Re: Beaks ITR Rear Swaybar Kit on a EK??? (10secwantabe)
I have a DC Sports Tie bar on my EK now, can i still use it w/ the ASR Bar? Also will i still use the beaks kit or just but the usual parts i need plus the ASR bar? thanks
Old Oct 16, 2005 | 07:22 PM
The ASR Bar take care of both. It adds rigidity and lateral support.
confucioussae
Suspension & Brakes
Sep 13, 2006 03:03 PM
1clean00EM1
Oct 9, 2005 01:42 PM
ransack
44
Oct 11, 2003 11:45 PM
BanEL
May 15, 2003 08:51 PM
civic23g
12
Nov 17, 2002 05:08 AM
