What sensor is this? Possible Vacuum leak?
Old Oct 8, 2005 | 01:41 PM
turbotime's Avatar
Default What sensor is this? Possible Vacuum leak?
anyone know what sensor this is? Looks like someone blacked it off with a piece of a pepsi can cause this cause a vacuum leak?
Old Oct 8, 2005 | 02:23 PM
Russ713's Avatar
dAng!
Default Re: What sensor is this? Possible Vacuum leak? (turbotime)
looks like the coolant area below the throttle body. It wont do much for you.
People will sometimes route the coolant lines AWAY from the throttle body to help cool intake temps, but it's neglible on daily drivers.
What was done on yours is most likely a useless job unless they did it as a temporary gasket.
Old Oct 8, 2005 | 02:26 PM
turbotime's Avatar
this is my daily driver, is it ok to leave it like this? i think it is completely blocked off
Old Oct 8, 2005 | 02:30 PM
Russ713's Avatar
dAng!
Default Re: (turbotime)
yeah, it won't hurt.
Old Oct 8, 2005 | 02:32 PM
turbotime's Avatar
cool thanks
Old Oct 8, 2005 | 02:43 PM
Luserkid's Avatar
Thats your fast idle from the looks of it. What the hell is that in it though? a piece of paper?
Old Oct 8, 2005 | 02:50 PM
turbotime's Avatar
its a piece of aluminum can to block off the port, apparently the valve itself is broken and was causing a vacuum leak
Old Oct 8, 2005 | 03:56 PM
m00nr0ck Si's Avatar
take the pepsi can out. if you wish to bypass the coolant from the throttle body , re -route the coolant lines, I could not sleep w/ that BS in there.
Old Oct 8, 2005 | 05:43 PM
TeamNextGenChris's Avatar
it's probably to make the fast idle valve nonfunctional.probably to cure the erratic/high idle problem they can cause.
the o-rings that seal the valve to the throttle body are on the valve,so there is a possibility that the piece of soda can isn't sealing against the TB,causing a vacuum leak.
remove the piece of aluminum,and ensure that the FIV is in proper adjustment,the re-install without the can:
https://honda-tech.com/zerothread?id=699787
chris
Hondapreludeg
Honda Civic (2001 - 2005)
14
Feb 18, 2013 02:23 PM
1990_integra_DA9
Oct 7, 2008 05:06 PM
90Rexx
Apr 7, 2008 04:31 PM
xlasianizelx
Mar 13, 2008 09:41 PM
CivicVX94
Jun 11, 2006 08:12 PM
