Removing Interior Parts?
Old Mar 4, 2002 | 03:23 PM
InfamousRS's Avatar
Default Removing Interior Parts?
I will be removing these interior parts from my 94 integra.
Dash
steering wheel
Interior Pillar peices
peices that go arround the back windows
My guestions with the dash and pillar peices is how do you remove them? Can someone give me a rundown of the process?
On the steering wheel, I have access to a steering wheel puller, but being that it has a airbag, is there a different way of removing it? What has to be done to the air bag before removing it?
I am trading interiors with someone, so I have to do this withough braking anything. I want it to go smoothly.
On the
Old Mar 4, 2002 | 03:41 PM
InfamousRS's Avatar
Default Re: Removing Interior Parts? (BLK94RS)
Oh, and what about taking the passenger side air bag out?
Old Mar 4, 2002 | 06:02 PM
InfamousRS's Avatar
Anyone?
Old Mar 4, 2002 | 06:10 PM
ThePunk's Avatar
Helms manual is your friend.
The pillar pieces just pop off by gently prying...
Old Mar 4, 2002 | 06:41 PM
InfamousRS's Avatar
Default Re: Removing Interior Parts? (ThePunk)
I don't have a helms manual right now. WOuld it be possible for someone to copy down the instructions for removing the dash for me. I don't need the pics, just the procedure.
Old Mar 4, 2002 | 09:13 PM
boosted1993fd's Avatar
Instrument panel, Dashboard lover cover, Knee bolster removal:
1. Lower the steering column.
2. Remove the screws and detach the clips, then remove the instument panel.
3. Remove the coin pocket.
4. Remove the screws and detach the clips, then remove the dashboard lower cover. -- Disconnect the connector.
5. Remove the knee bolster.
Stereo radio/cassette, Heater control panel removal:
(not going to list the radio removal...hopefully you know how to already, skipping to heater control panel removal)
3. Carefully pry the hazard warning switch and rear window defogger switch out of the header control panel. -- Disconnect the connectors.
4. Remove the screws. -- Detach the harness clips and connector clip.
5. Disconnect the air mix control cable from the heater unit.
6. Pull the heater control panel out, then disconnect the connectors.
Side air vent removal:
Driver's:
1. Pry out the moonroof switch out of the side of the air vent.
2. Remove the screw, then remove the side air vent.
Passengers:
1. Follow #1 above
Side defogger trim removal:
1. Just pry out.
Clock removal:
1. Pry the clock at the left edge, then pull it out. Disconnect the connector.
Glove box removal:
1. Open the glove box.
2. Remove the screw, then remove the damper from the glove box.
3. Remove the screw, then remove the glove box.
4. Remove the damper and striker.
Before removing the dashboard:
1. Disconnect the negative battery terminal, then disconnect the positive cable.
disconnect driver's side air bag and passengers side air bag connectors...
everything else is pretty self explanitory.....plus I have to goto work...so if you have a question ask
Old Mar 4, 2002 | 09:46 PM
InfamousRS's Avatar
Default Re: Removing Interior Parts? (Interlude)
Thanks!
Old Mar 4, 2002 | 10:24 PM
InfamousRS's Avatar
Does it say anything in the Helms manule about removing the steering wheel?
Rikaro
Apr 26, 2008 11:14 PM
LaEzEnT
Oct 23, 2007 05:54 PM
3.3.3
Feb 17, 2004 04:19 PM
InfamousRS
Mar 5, 2002 04:02 PM
