STOCK B18c1 bottom end
Stock GS-R Block
Toda A Cams
Skunk2 Gears
AN-R IM
Hondata IM Gasket
Stock GS-R TB
Ebay 3" Intake w/K&N
Dented DC Header
2.5" Carsound
Crappy Condition Tanabe Racing Medallion
Tuned w/Uberdata by "Leed" ...I only got 5 runs unfortunately because we discovered I had a bent wheel on my 4th run.
Relatively "stock" compared to what defines an NA Honda these days.
edit - where's your dyno sheet?
Modified by alfaaay at 5:13 PM 10/8/2005
Toda A Cams
Skunk2 Gears
AN-R IM
Hondata IM Gasket
Stock GS-R TB
Dented DC Header
2.5" Carsound
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smkngsr »</TD></TR><TR><TD CLASS="quote">thats some good whp u got in there, i wonder how the GSR will do with same setup as urs (stock comp) with spec b cams and upgraded valvetrain</TD></TR></TABLE>
Thanks! I feel like the whp number is a little low, but I'm making pretty good torque and the car feels good to drive. Unfortunately, the chances of me investing more into an NA setup (IE a GOOD header, better exhaust, etc.) are slim since I want to go turbo next summer.
I think Toda B's would be over camming. Would I do it? Yeah, probably. This is just a prediction based on what I know about flow and dynamic compression, but you'll make more peak power (185 to 190-ish?), at a higher RPM, and have less torque. It'll be definitely be faster, but it won't have as nice a torque curve or powerband or as much whp as it could if it had upped compression.
Modified by alfaaay at 8:18 PM 10/8/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Easyslider01 »</TD></TR><TR><TD CLASS="quote">bc3+ cams
4-1 header
hondata
sk2 IM
181 whp and 127tq on dynojet before touching the cam gears. This was not UAE corrected however.</TD></TR></TABLE>
i know BC3+ makes some crazy midrange throughout the power band but im kinda leaning towards skunk2 stage 2 or toda spec b cams...ive been having hard time to decide on the cams for few months because everybody had their own opinions and its so hard to decide which is which...
4-1 header
hondata
sk2 IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay »</TD></TR><TR><TD CLASS="quote">Stock GS-R Block
Toda A Cams
Skunk2 Gears
AN-R IM
Hondata IM Gasket
Stock GS-R TB
Dented DC Header
2.5" Carsound
Modified by alfaaay at 5:13 PM 10/8/2005</TD></TR></TABLE>that is actually good #'s.....stock block..and head no port??.....props..man
Toda A Cams
Skunk2 Gears
AN-R IM
Hondata IM Gasket
Stock GS-R TB
Dented DC Header
2.5" Carsound
well heres mine
stock block c1
pnp/5 angle vj
milled.20
blox 2
ferrea valvetrain
skunk im
stupid dc headers
toda camgears
full pipping exhaust
honda s200
p28 jun program
179.2 116 lbs trq..
why is my trq so low?? maybe the dented headers?
next mod: smsp headers, type r tb, 440cc inj
my tuner told me that im maxing my injectors and suggested 440 im still debating that it'll b overkill...any help??..
stock block c1
pnp/5 angle vj
milled.20
blox 2
ferrea valvetrain
skunk im
stupid dc headers
toda camgears
honda s200
p28 jun program
179.2 116 lbs trq..
why is my trq so low?? maybe the dented headers?next mod: smsp headers, type r tb, 440cc inj
Wow nice #'s guys
andyways does dents on the header effect tq? reason im asking is because my friend has a T1R 4-1 header and has a nickle size dent on one of the runners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Serdar »</TD></TR><TR><TD CLASS="quote">Wow nice #'s guys
andyways does dents on the header effect tq? reason im asking is because my friend has a T1R 4-1 header and has a nickle size dent on one of the runners.</TD></TR></TABLE>
Nickel size? It probably won't be that bad of a restriction. Here's what my DC header looks like:
eff the U.Washington University District roads and random construction sites
btw, right next to the header is the resonator from my Tanabe Racing Medallion. Eff crappy manufacturing. A crack started forming a few months prior to the dyno day, I thought it was just a rattle, then one day on the freeway, CRACK!
andyways does dents on the header effect tq? reason im asking is because my friend has a T1R 4-1 header and has a nickle size dent on one of the runners.</TD></TR></TABLE>Nickel size? It probably won't be that bad of a restriction. Here's what my DC header looks like:
heres mine...just got it back from inline:
OBD1 JDM GSR Motor
Skunk2 Intake Manifold
DC Sports JDM ITR 4-1 Header
2.5" Test Pipe
RS*R EX-MAG Catback Exhuast
K&N Filter Kit W/ Stock Intake Arm
Any good pointers to help me get this daily driver a little more whp?
OBD1 JDM GSR Motor
2.5" Test Pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorjdism »</TD></TR><TR><TD CLASS="quote">heres mine...just got it back from inline:
OBD1 JDM GSR Motor
2.5" Test Pipe
Any good pointers to help me get this daily driver a little more whp?</TD></TR></TABLE>it seems kinda low..what kind of fuel management??...is it tuned??..
OBD1 JDM GSR Motor
2.5" Test Pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PAndADc2 »</TD></TR><TR><TD CLASS="quote">it seems kinda low..what kind of fuel management??...is it tuned??..</TD></TR></TABLE>
It was tuned on hondata.
Munkyw3rkz.webs.com
my old old old set up back in my hatch was a stock
USDM GSR block
P&P PR3 head
milled 20 thou
reworked Chambers
ITR valves
JG springs /retainers
RS MACHINE cams
AEBS IM
stick TB
Stock intake box with 3" pipe arm
JDM ITR header
V-AFC 181whp 132ft lbs
USDM GSR block
P&P PR3 head
milled 20 thou
reworked Chambers
ITR valves
RS MACHINE cams
AEBS IM
stick TB
JDM ITR header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake »</TD></TR><TR><TD CLASS="quote">my old old old set up back in my hatch was a stock
USDM GSR block
P&P PR3 head
milled 20 thou
reworked Chambers
ITR valves
RS MACHINE cams
AEBS IM
stick TB
JDM ITR header
</TD></TR></TABLE>ImPressive
USDM GSR block
P&P PR3 head
milled 20 thou
reworked Chambers
ITR valves
RS MACHINE cams
AEBS IM
stick TB
JDM ITR header
My friends integra made 166 whp and i forget the actual tq number. Damn i cant find the dynosheet but it was on a dynojet 249c.
The mods were:
Skunk2 IM
Stock ITR ARM and Box
JDM ITR Header
2.75 Kakimoto Exhaust with a shitty catco 2.5inch clogged header.
Woulda made im sure maybe a tad bit higher with the test pipe hes running now.
Also there was no tuning done just on a base map for hondata. Im sure with skunk stg. 1s and hondata tuning 18x would be possible.
The mods were:
Skunk2 IM
JDM ITR Header
Munkyw3rkz.webs.com
USDM GSR block
P&P PR3 head
milled 20 thou
reworked Chambers
ITR valves
RS MACHINE cams
AEBS IM
stick TB
JDM ITR header
forgot to mention that that was with Exhuast hooked up 2.5" with ES OVAL and with the CAT still in place
USDM GSR block
P&P PR3 head
milled 20 thou
reworked Chambers
ITR valves
RS MACHINE cams
AEBS IM
stick TB
JDM ITR header
</TD></TR></TABLE>forgot to mention that that was with Exhuast hooked up 2.5" with ES OVAL and with the CAT still in place
the.hamburglar
Jun 25, 2006 12:46 PM
