ran into a problem with b16 swap
Old Oct 8, 2005 | 11:18 AM
1sikhatch's Avatar
Default ran into a problem with b16 swap
ok i got the swap out of a eg coupe and im putting it in my ek hatch today and i looked at the motor and its sitting up to far to the front so i'm thinking if its the rear bracket thing. Are the brackets the same? if not what motor can i get the right bracket from?
Old Oct 8, 2005 | 11:39 AM
chad's Avatar
Moderator
Default Re: ran into a problem with b16 swap (1sikhatch)
rear brackets for eg/dc with bseries are different than the ones for eks...
ek's are about 1.5 inches shorter....you will need a bracket out of a 99-00 civic si to put this engine in your car
you will also need to add a crank fluctuating sensor on the crank....
and obd2 injectors and alternator
hope that helps
Old Oct 8, 2005 | 11:43 AM
1sikhatch's Avatar
Default Re: ran into a problem with b16 swap (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">rear brackets for eg/dc with bseries are different than the ones for eks...
hope that helps
thanks now i gotta look for one of these,
btw, i have a obd1 jumper harness with a p28 ecu and obd1 injectors. what is the crank fluctuating sensor for?
Old Oct 8, 2005 | 12:12 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">
what is the crank fluctuating sensor for?</TD></TR></TABLE>
it counts the amount of rotations per second or something like that, help me out &lt;chad&gt; ...
Old Oct 8, 2005 | 01:54 PM
chad's Avatar
Moderator
it is on the oil pump....the crank fluctuation thingy
Old Oct 8, 2005 | 02:06 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">it is on the oil pump....the crank fluctuation thingy</TD></TR></TABLE>
thats what i thought, i had to put in one b/ i converted the engine to obd2 also.
Old Oct 8, 2005 | 03:17 PM
1sikhatch's Avatar
Default Re: ran into a problem with b16 swap (EJ8VTEC)
so that crank fluctuation is only for obd2 then? does the stock single cam come with them?
Old Oct 8, 2005 | 03:43 PM
pennies_hatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">so that crank fluctuation is only for obd2 then? does the stock single cam come with them?</TD></TR></TABLE>
yes, but the plugs are different.
if you're doing the jumper harness to obd1, you dont need it and as far as the rear mount. get the 99-00 si; b16a2 rear mount
shocker911
Dec 31, 2013 12:01 AM
ef9_lover
Apr 30, 2012 03:33 PM
wade
Oct 25, 2008 06:02 AM
invisible
Jan 9, 2007 11:05 AM
94CivSi
Apr 17, 2003 11:56 AM
