that notorious crx roof leak. please help
got a 91 si. basically in mint condition. i mean mint 160k miles. (still chirps third). anyway the sum om a bitch leaks water from the rear hatch hydrolic lifters. i got the roofliner off and the sunroof assembly looks clean w/no rust. has anyone had and was able to fix this problem? if anyone can tell me how to load an image i could show u the problem. thanx
I have the same problem with my bro's rex. His is a 90 HF. Its coming from the passenger side lift. Haven't spent much time worrying about it since its just parked inside. When we brought it home, we hosed her down to take all the bird crap off, and the next morning when we took the carpet out, there was a substantial amount of water in the spare tire inset.
I'll take another closer look at it tonight and see if i can find a fix.
good to know, im pretty sure everyone has the leaking problem but i havent herd of anyone replacing all the seals and moldings yet hopefully soon
HF DX SI, It is common to have a rex that drips, Like above says moldings, rubber trim around the hatch and doors. After all there 14+ years old, moldings rubber trim etc get brital...
this is why the search button is useful, here I did it for you.
https://honda-tech.com/zerothread?id=1034142
if the drain tubes are in place and clear then look into resealing the two roof lines especially by the back where the hatch starts.
otherwise its your taillight gaskets....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink »</TD></TR><TR><TD CLASS="quote">otherwise its your taillight gaskets....</TD></TR></TABLE>
I'd like to see water get from my tail lights to my hatch struts...
I have this same problem, and all my sunroof drain tubes are clear, etc. One of these days I'm going to take off the mouldings and honda-bond the **** out of everything. It's been raining the past few days, my car smells like feet.
