96 dx automatic to manual conversion
Old Oct 7, 2005 | 08:24 PM
rollercosta123's Avatar
Default 96 dx automatic to manual conversion
i have a 96 dx hatch automatic and i have a stic h22 in my garage i got detailes for swap info but is the chasis the same, help what do i need to do?
Old Oct 7, 2005 | 10:28 PM
Kendall's Avatar
The chassis is the same as the manual cars and mounting the motor won't be a problem. You'll need to purchase the clutch hard lines and a new pedal assembly. If you have an older H22 with the engine harness ending at the shock tower, then you'll need to purchase a new harness, or modify your stock harness. You'll also have to bypass the neutral safety switch, but that's easy.
TypeR0186
Sep 26, 2008 03:17 PM
SrT4u2nV
Feb 4, 2007 08:52 AM
awdriscol4
Feb 6, 2005 01:15 PM
jdmitr
Feb 17, 2003 03:55 PM
2000_Civic_Si
Aug 15, 2002 03:24 AM
