Think my clutch cylinder may be going
Old Oct 7, 2005 | 05:52 PM
turboman's Avatar
Default Think my clutch cylinder may be going
After I drive a bit the clutch seems to drop about 1/2 inch. Otherwise it works fine though. Is this the master cylinder or the slave cylinder or both?
Since the car is getting older I was considering replacing the clutch and brake cycllinger and also all 4 calipers. Is this just a was of money or a good safety precaution?
Old Oct 7, 2005 | 05:55 PM
Deemeetree's Avatar
Electrician
Have you checked for any fluid leaks at any of the fittings or hoses? Have you checked for any leaks on the inside of your car where the clutch pedal is connected to the "linkage rod"? Determine what it is first.
Old Oct 7, 2005 | 06:00 PM
e jay one's Avatar
Default Re: (Deemeetree)
clutch master cylinders are known to go out. mine did.
PaulMc
May 18, 2014 05:04 PM
beanwagon
Dec 12, 2008 02:55 PM
RDAYA0
Dec 14, 2006 05:31 PM
RaceMyGhost
Dec 26, 2005 09:51 PM
phantom_sol
Oct 8, 2003 08:14 PM
