h22 swap will barely run please help
I am totally out of ideas my h22 swap will now start but runs really bad
I have the firing order right
timing is right
all plugs fire
i dont know what is wrong
the timing was at 10 when it should be at 12 when i got the engine, could the valves be bent and making it run really bad? it sounds like its running on 2 cylinders
compression is 145 165 145 165 but keep in mind my compression tester reads low i think because a good B18b had 140-145 and that was warm and of cousre my h22 was tested cold because it doesnt really run
ANy ideas would be much appreciated
timing is right
all plugs fire
boosted92hatch
56
Feb 6, 2008 12:12 PM
neronian
Mar 28, 2004 12:21 PM
neronian
Mar 26, 2004 10:56 AM
