Running rich? valve clearance
Old Oct 7, 2005 | 09:32 AM
Rus1an's Avatar
Default Running rich? valve clearance
after i did valve clearance my a/f gauge showed that i was rich (to the end). I know its not to acurate but i know im running rich. I double checked the valve clearance with a feeler gauge and all was good. does anyone have a clue why this would be?
thanks alot
Old Oct 7, 2005 | 11:03 AM
1bad-eg's Avatar
Default Re: Running rich? valve clearance (rus1an)
Need more info. What type of motor, any bolt ons, etc.?
Old Oct 7, 2005 | 11:16 AM
BlackLudeSi's Avatar
Default Re: Running rich? valve clearance (1bad-eg)
Were your valves way out of wack? I'm trying to remember but i think he has a GSR swap in the DA. If your valves were really bad your ecu might have been compensating for them. Did you try just reseting the ecu? I've seen it more than once a car with a dizzy or valves way off after its fixed we needed to reset ecu
Old Oct 7, 2005 | 12:25 PM
Rus1an's Avatar
Default Re: Running rich? valve clearance (BlackLudeSi)
it wasnt way off and yes i reset the ecu but nothing yet so im going to play around with it tonight and hopefuly figure this out.
Old Oct 8, 2005 | 04:20 PM
Rus1an's Avatar
I figured it out, I guess I had them a little too tight. So insted of using 007 on the exhaust I used 008 and evreything is fine. thanks evreyone
mouab18c1
Engine Management and Tuning
17
Jul 29, 2012 01:08 AM
planetstereo
Oct 4, 2005 05:21 PM
_Endless_
Aug 18, 2003 06:57 AM
VTgringo
Aug 15, 2003 03:18 PM
LshatchTurbo
Aug 9, 2002 01:48 AM
