Have another tire question
Old Oct 7, 2005 | 06:17 AM
IntegraTypeR's Avatar
Default Have another tire question
Well i made up my to go for the Hankook tires and will buy soon some slipstreams in 16x7, 4x100 bolt pattern and 45mm offset and the tires i dont know which to choose from are 215/45/16 or 215/40/16
well i was recommend to go for the 45% profile, but when i try the tire caculator on this link: http://www.7thgencivic.com/index.php?page=tirecalc
when i tried 215/45/16 it showed that the speedometer will read %4.53 slower
while
when i tried 215/40/16 it showed that the speedometer will read %0.7 slower
thats when i used stock tire was 175/70/13
Now i heard if i go with the 45mm offset i wont rub and dont know if i can fit the 215/40/16 cause from the tire calculator the 40% profile is close to stock specs and the speedometer will read much more accurate than 45%.....what do you guys think?
Km
Modified by IntegraTypeR at 4:08 AM 10/8/2005
Old Oct 7, 2005 | 03:06 PM
Default Re: Have another tire question (IntegraTypeR)
bump
Old Oct 7, 2005 | 05:55 PM
bump2
Old Oct 7, 2005 | 07:55 PM
bump3
Old Oct 8, 2005 | 10:25 AM
bump4
Old Oct 8, 2005 | 04:10 PM
bump5
Old Oct 8, 2005 | 05:43 PM
nsxtasy's Avatar
H-T Order of Merit
The reason you're getting a different answer is because the stock tire size on your Integra isn't 175/70-13. I believe it's 185/65-14. 215/40-16 (or 205/40-16) is a good size for a Civic that comes with 175/70-13; 215/45-16 (or 205/45-16) is a good size for an Integra that comes with 185/65-14.
Old Oct 8, 2005 | 10:27 PM
Default Re: Have another tire question (nsxtasy)
This is going on a 99 Honda civic hatchback !!!!
Modified by IntegraTypeR at 6:30 PM 10/9/2005
Old Oct 8, 2005 | 10:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The reason you're getting a different answer is because the stock tire size on your Integra isn't 175/70-13. I believe it's 185/65-14. 215/40-16 (or 205/40-16) is a good size for a Civic that comes with 175/70-13; 215/45-16 (or 205/45-16) is a good size for an Integra that comes with 185/65-14.
so if i fit 215/40/16 on my 99 civic hatch and 1.75 drop will i rub here even if am on 45mm offset rims?
Old Oct 9, 2005 | 05:35 AM
bump
Old Oct 9, 2005 | 03:17 PM
more bump
Old Oct 9, 2005 | 03:25 PM
which of these two tires to go for 215/45/16 or 205/45/16 if the rims are 16x7 and 45mm offset?
let me know guys!
Old Oct 10, 2005 | 05:46 PM
nsxtasy's Avatar
H-T Order of Merit
205/45-16 will give you less chance of rubbing. That's what I would go for.
Old Oct 22, 2005 | 09:24 AM
thr33niL's Avatar
I was slightly rubbing with my 205/45/16's on a 2.25 inch drop and 42 offset. That was only over some extreme bumpage. 45 offset should set it pretty well.
Old Oct 23, 2005 | 01:20 PM
if am going with a 16x7, 4x100 bolt pattern and +38mm offset do u think if i go with 205/40/16 and lets say Max 2" drop....now is there any chances of rubbing here?
Note: this is going on a 99 civic hatch!
Old Oct 24, 2005 | 06:12 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR &raquo;</TD></TR><TR><TD CLASS="quote">if am going with a 16x7, 4x100 bolt pattern and +38mm offset do u think if i go with 205/40/16 and lets say Max 2" drop....now is there any chances of rubbing here?</TD></TR></TABLE>
Well, you'll have to try it to be sure, but probably not, except possibly under maximum compression (as threenil notes). I would still stick with the 45 aspect ratio (205/45-16). Its outer diameter is already smaller than stock (by 0.9 percent). If you go 205/40, your outer diameter will be WAY smaller than stock (4.3 percent) and this will throw off your speedometer and odometer by that amount. You really don't want to do that. Get the 205/45-16 size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Note: this is going on a 99 civic hatch!</TD></TR></TABLE>
Thanks for the clarification. However, unlike many of the earlier Civic hatches (which had stock sizes of 175/70-13 or 185/60-14), the '99 Civic DX hatch has a stock size of 185/65-14, which has almost exactly the same (0.1 percent difference) outer diameter as the '94-01 Integras, so that really doesn't change the size recommendation.
Cliff's notes: Get 205/45-16.
Old Oct 24, 2005 | 10:20 PM
but the only tires Falken RT-615 only available now in 205/40/16!!!
here is a link: http://www.vulcantire.com/azenis_rt615_t.htm
Old Oct 25, 2005 | 06:39 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR &raquo;</TD></TR><TR><TD CLASS="quote">but the only tires Falken RT-615 only available now in 205/40/16!!!</TD></TR></TABLE>
Which is why the Hankooks are a better choice than the RT-615. (Who said anything about the Falkens, anyway?) I assume you were talking about the Hankook Ventus R-S2 Z212, which is similar to the Falken RT-615. Both are very sticky tires, sort of in between street tires and R compound track tires. The Z212 is available in 205/45-16 for $89/tire (from Discount Tire) and will be fine for your '99 Civic hatch.
Eran
Nov 17, 2011 10:50 PM
1-Bar
Jun 1, 2003 03:47 PM
j_ambrose
Dec 14, 2002 10:58 PM
Napolean Solo
Sep 29, 2002 04:41 PM
