mini me problems please help me last resort
i have a d15b7 new mains new rod bearings new rings with a y8head 3 aqngle valve job new retaniers with a crane cam b18 cam gears y8 mani p28 virgin ecu not running vtech also using a hacked up b16 dizzy using a z6 cork head gasket this motor only has 2500 miles on it and blew 2 head gakets first was a y8 head gasket (metal) second was a z6 cork any ideas how i can stop this problem what gasket u think i should be runing and today before it blows it starts to over heat and blow hoses after i fix the house i start it and water and oil start shooting out the exaust now what i dont under stand is this thing runs prime then just dies
Sounds like your head is warped to me. If it is and you don't get it milled down, you'll continue to blow head gaskets all year long. I'd definatly go with the y8 head gasket. I work at honda and we almost never install the cork ones. We usually install the y8 gaskets whenever possible cause they're alot stronger.
Even though it was milled and professionaly built, it could still be warped. I'm sure the builders milled it properly and everything. It could have warped on you the first time it overheated. Maybe your thermostat froze up on you or something else may have caused it to overheat and caused the head to warp. Those aluminum heads are pretty easy to warp when they overheat. I hope for your sake too that i'm wrong, but that's the direction i'd lean towards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG »</TD></TR><TR><TD CLASS="quote">Even though it was milled and professionaly built, it could still be warped. I'm sure the builders milled it properly and everything. It could have warped on you the first time it overheated. Maybe your thermostat froze up on you or something else may have caused it to overheat and caused the head to warp. Those aluminum heads are pretty easy to warp when they overheat. I hope for your sake too that i'm wrong, but that's the direction i'd lean towards.
While your taking the head of anyways to replace the headgasket might as well take it to the shop and let them look at it, if they did it once they will take a look for free.
one problem i live in pa it was done in tenn im gonna just try it and hope for the best it over heated do to a blown heater core line any possible way it just blew because it overheated or is it more def warp has a head gaket ever blown just fro anover heat and could just be replaced or could it have somehting to do with the high compression from the mini me im not exactly sure how high it would be from this
i think i no why it blew i just got this motor off my good friend hes the one that had it built i didnt no right before i put it in my car he put a new head gasket on it and when i put it in my car i started to jump on it alot could this of blown the head gasket
I used a MR Gasket Multi-Layered Steel head gasket for Z6 when i did my mini-me. it was only 40-50 bux and worked great. I wouldnt bother with a cork one, and I believe the OEM y8 HG is slightly thinner than the Z6 which will slightly bump up your compression (.5 at most) but if youre already getting your head milled then that's going to be some high compression!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">I used a MR Gasket Multi-Layered Steel head gasket for Z6 when i did my mini-me. it was only 40-50 bux and worked great. I wouldnt bother with a cork one, and I believe the OEM y8 HG is slightly thinner than the Z6 which will slightly bump up your compression (.5 at most) but if youre already getting your head milled then that's going to be some high compression!</TD></TR></TABLE>
umm, yeah. no. try again buddy. 92-00 vtec head gaskets are ALL the same. same MLS, same thickness. know your info before u speak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by necxoner »</TD></TR><TR><TD CLASS="quote">one problem i live in pa it was done in tenn im gonna just try it and hope for the best it over heated do to a blown heater core line any possible way it just blew because it overheated or is it more def warp has a head gaket ever blown just fro anover heat and could just be replaced or could it have somehting to do with the high compression from the mini me im not exactly sure how high it would be from this</TD></TR></TABLE>
Usually what happens is the Head warps from overheating and then the head gasket follows right after. It is possible for a head gasket to blow from overheating without warping the head, but very unlikely. Anytime a customer brings a car in for a new head gasket, we pull the head and check it with a straight edge and feeler guages. If we're at all suspicious of a warped head we'll send it straight off to the machine shop to be checked and milled if necessary. You can try the straight edge and feeler gauge rout if you want, but i'd just suggest taking the head to a local machine shop to get checked out. If it's not warped, they'll tell you and probably wont even charge you.
JDMRPM
Sep 30, 2012 04:33 AM
