V-tec solenoid question
Old Oct 6, 2005 | 07:11 PM
FuNkDrSpOt's Avatar
Default V-tec solenoid question
are the solenoids from a 97 Ex ( d16y8 ) and a 97 GS-R ( b18c ) the same? My mechanic is saying that the solenoid from my car wont work on my JDM b18c because the bolt holes are different. I want to see if anyone who has actually done a swap can tell me.....
Old Oct 6, 2005 | 11:02 PM
FuNkDrSpOt's Avatar
Default Re: V-tec solenoid question (jrepa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrepa &raquo;</TD></TR><TR><TD CLASS="quote">no I have the same swap
You need to get a b series one
You can plug the vtec soleniod that you have but you need to extend the wire and you need to use a jdm gsr ecu so you won't throw any codes
Modified by jrepa at 11:58 PM 10/6/2005</TD></TR></TABLE>
....expletive
Old Oct 8, 2005 | 10:38 AM
i heart HT's Avatar
Default Re: V-tec solenoid question (i heart HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i heart HT &raquo;</TD></TR><TR><TD CLASS="quote">expletive?</TD></TR></TABLE>lol expletive that
Old Oct 9, 2005 | 01:02 AM
jadsi420's Avatar
Default Re: V-tec solenoid question (FuNkDrSpOt)
are you going to use the jdm ecu? i don't know if it is the same but i swapped a 2000 itr motor into my 99si recently and there was no need to add the solenoid as long as i used the jdm ecu because the programming for the jdm ecu doesn't use this solenoid. i think yours would be the same? I did a search for the same question and found a ton of info. good luck witht the swap.
Old Oct 9, 2005 | 10:50 PM
JDM1civic's Avatar
Default Re: V-tec solenoid question (jadsi420)
yes, the vtes solinoid off a d16 will bolt up to a b16/18....some say it has less oil pres and vtec doesnt fell as stong but i think thats b.s. vtec is on, or off there is no in between, so i dont see an issue with using it
sce310
Honda Civic (2006 - 2015)
32
Nov 4, 2006 07:33 PM
jpizzi
11
Aug 29, 2006 12:56 PM
LvN
56
Jun 26, 2006 09:50 AM
FuNkDrSpOt
31
Oct 9, 2005 11:56 AM
spectacle
16
May 6, 2005 01:28 PM
