thermostat question??
sup i have a gsr motor...and i never changed a thermostat in my life...im guessing that it is on the lower radiator hose that attaches some where around the manifold?? is it the lower rad hose?? the one i have to follow or the upper? thanx
Hehe, I saw you post this in the Type R forum.
Anyway, follow the lower radiator hose. It will go into the block (not any sort of manifold like you say). There you will see it goes into something that's round shaped. That piece of the block can be unbolted with two 12mm (or might be 10mm) bolts.
Do a search on "thermostat" in the Integra forum and you'll find several threads on it, along with some pictures.
It's a very easy procedure and should take you 15 minutes, even if you have no auto mechanical knowledge. Note, that you will need to drain at least some of the coolant.
EDIT: These might help:
https://honda-tech.com/zerothread?id=1360304
https://honda-tech.com/zerothread?id=1355563 (Hey, I posted in that
And woah...here's the best one: http://www.team-integra.net/se...D=222 (with pictures
)And woah...here's the best one: http://www.team-integra.net/se...D=222 (with pictures
