JDM ITR...weight of the hood?
Old Oct 6, 2005 | 02:31 PM
Azcheron's Avatar
Default JDM ITR...weight of the hood?
could someone tell me what a JDM ITR hood weighs...thanks
Searched and found nothing
Old Oct 6, 2005 | 02:33 PM
revvin9k's Avatar
Default Re: JDM ITR...weight of the hood? (Azcheron)
May I be the first to ask why? I would imagine the same as the USDM hood. I did'nt know they were different. I learn something new everyday.
Old Oct 6, 2005 | 02:50 PM
SilverDc2's Avatar
Default Re: JDM ITR...weight of the hood? (S2K NUB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K NUB &raquo;</TD></TR><TR><TD CLASS="quote">May I be the first to ask why? I would imagine the same as the USDM hood.</TD></TR></TABLE>
HUGE difference, JDM is a lot heavier usdm isn't that bad..jdm ones probably weighs 8 lbs more
Old Oct 6, 2005 | 02:59 PM
Booker's Avatar
Banned Duplicate Account
Default Re: JDM ITR...weight of the hood? (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">HUGE difference, JDM is a lot heavier usdm isn't that bad..jdm ones probably weighs 8 lbs more</TD></TR></TABLE>
If not more then 8lbs.
Old Oct 6, 2005 | 04:10 PM
SecretAgent's Avatar
yeah, JDM is WAY heavier than USDM. it's a lot bigger too.
Old Oct 6, 2005 | 04:24 PM
JDM Factor's Avatar
I think it's 9-10 pounds more when i weighed mine...
Old Oct 6, 2005 | 08:17 PM
Desired_Speeds's Avatar
Default Re: (SecretAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAgent &raquo;</TD></TR><TR><TD CLASS="quote">yeah, JDM is WAY heavier than USDM. it's a lot bigger too.</TD></TR></TABLE>
that makes sense
Old Oct 6, 2005 | 09:35 PM
n-line4's Avatar
Default Re: (Desired_Speeds)
the heavier weight is due to the size of the hood right?
Old Oct 6, 2005 | 09:39 PM
Default Re: (n-line4)
i would assume so. the metal doesn't appear any thicker.
Old Oct 6, 2005 | 09:41 PM
I'm pretty sure all honda hoods are similar in metal, they seem to be structured the same also, the metal seems better than Toyota metal also
Old Oct 6, 2005 | 11:26 PM
jdm2teg's Avatar
wow i learned something new today. good thing i have cf hood for me. .....but wait doesnt jdm cf hood weight more than usdm cf hood? dammit
Old Oct 7, 2005 | 08:11 AM
Azcheron's Avatar
Default Re: (jdm2teg)
thanks guys!
does anyone know total weight of the hood?
or the weight of a USDM, so i can add the 9-10 lbs to it for the JDM hood?
Old Oct 7, 2005 | 11:48 AM
realis9's Avatar
Default Re: (Azcheron)
so how much lbs would i save if i go from a jdm hood stock hood to a Cf jdm hood?
Old Oct 7, 2005 | 11:57 AM
Flux's Avatar
Default Re: (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">so how much lbs would i save if i go from a jdm hood stock hood to a Cf jdm hood?</TD></TR></TABLE>
x-y=z
x=Weight of JDM stock hood
y=Weight of CF hood
z=Total weight difference (savings)
Old Oct 7, 2005 | 12:55 PM
SilverDc2's Avatar
Default Re: (Flux)
honestly i'd say a good 30 lbs, if you get a lightweight one,
VIS = heavy 18-20 lbs
sunny stylings = 8-10 lbs
Old Oct 7, 2005 | 02:52 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys!
or the weight of a USDM, so i can add the 9-10 lbs to it for the JDM hood?</TD></TR></TABLE>
The USDM hood was approximately 31 lbs. when I weighed mine.
Old Oct 8, 2005 | 06:45 AM
Azcheron's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
The USDM hood was approximately 31 lbs. when I weighed mine. </TD></TR></TABLE>
exactly what i wanted to know!
thanks!
Mr.Death
Dec 6, 2007 11:03 AM
Problemo
Mar 10, 2006 12:06 AM
Stunna MIKE
Nov 24, 2005 12:21 PM
nsxjr2
Nov 18, 2004 01:34 PM
itr_18
Mar 9, 2004 10:23 PM
