Umm...i dont get it
Old Oct 6, 2005 | 02:04 PM
brockscivic's Avatar
Default Umm...i dont get it
Ok, after researching for months about the JDM P08 ECU and the D15B vtec, i finally got my ecu and things today. The plan was:
JDM D15b running on a P08 ECU with a CX wire harness (both 1-wire o2)
Now, everywhere i looked i found that the P08 doesnt look for a vtec pressure switch (and i figured as much seeing as my JDM motor doesnt have one in it) but why in the hell am i getting a Code 22. Which unless the haynes manual is incorrect is the vtec pressure. Did i wire the vtec wire to the wrong pin in the harness or what? someone please help me
Old Oct 6, 2005 | 03:29 PM
david
Guest
Posts: n/a
Default Re: Umm...i dont get it (brockscivic)
it does look for a both the vtec pressure switch and the vtec solenoid.
-check your wires
-check your oil
-check your ground
if you have the cel still... somebody else can help you.
Old Oct 6, 2005 | 05:46 PM
Default Re: Umm...i dont get it (david)
the JDM motors had the switch built in the ECU and not actually on the solenoid. Kinda complicated...i read about bypassing it. But i want it to be fixed not band-aid'ed
Old Oct 26, 2005 | 05:34 AM
bmw626's Avatar
do the paperclip trick and jump the connection .... i forgot what pins it goes in but it works good
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
Eli Mac 67
Jun 6, 2007 05:01 PM
nutball72
Aug 26, 2006 10:54 AM
Gonzo_SiR
Apr 12, 2004 08:28 PM
98HB
Mar 16, 2003 02:16 PM
