obd1 b16a into 99 civic with a twist
Old Oct 6, 2005 | 07:58 AM
PURPLETERROR aka BIGMATT's Avatar
Default bad hesitation obd1 b16a into 99 cx
Im installing a 93 b16a with lsd into a 99 hatch, I didnt order this motor personally, and the engine importer converted it to obd2 by changing the injectors, alternator, and dizzy. motor is in and running, no cel's but it is hesitating and bogging and driving very sluggish, but at other times will run ok. there is no cat, and i converted it to obd1 with a jdm p30. I think it may be a bad map sensor, tps checks out fine with a volt meter.
Modified by PURPLETERROR aka BIGMATT at 12:29 AM 10/12/2005
Old Oct 6, 2005 | 01:16 PM
function83's Avatar
Default Re: obd1 b16a into 99 civic with a twist (PURPLETERROR aka BIGMATT)
use a jdm obd2a ecu cuz they don't run ckf sensors.
or convert to obd1 with a jumper harness.
goodluck.
Old Oct 6, 2005 | 02:32 PM
Old Oct 11, 2005 | 03:29 PM
Default Re: (PURPLETERROR aka BIGMATT)
bump
Old Oct 13, 2005 | 08:20 AM
Default Re: bad hesitation obd1 b16a into 99 cx (PURPLETERROR aka BIGMATT)
anyone
Truedeal
Engine Management and Tuning
Dec 4, 2017 07:09 AM
HOMEMADEPOWER
Dec 29, 2015 05:27 PM
NOman0608
May 12, 2007 08:39 PM
DetainedCivic
Apr 17, 2006 10:52 AM
boostin4drcivic
Apr 30, 2004 11:40 AM
