ignition for nitrous
Ok so I came to my senses and decided not to boost my 11ish:1 b16. Instead I am going to spray it. What ignition setup do you guys recommend?
I am thinking.
MSD Digital-6 Plus
Blaster 2 Coil or SS Coil
Modified by doublejz at 3:00 PM 10/6/2005
I am thinking.
MSD Digital-6 Plus
with the MSD dig 6 Plus I won't need the retard box right? Also, people are always saying dont use no2 if you mis-shift your done.... If your using the the solenoid that only sprays when WOT and you shift correctly (heal to toe), you shouldnt be WOT if you miss a gear, unless your slamming gears/power shifting (screwing your synchros) not letting go of the gas.... correct me if I'm wrong
also check NX maximizer II it's a RPM based and u can control the amount of n2o. Like say u want a 25shot at 1st gear from 4500 to 4500 in 2nd gear and 50 shot at 4600 in 2nd gear to 4000 in 3rd and 4100 to redline the full shot
