SRS light on steady and dead horn. related somehow???
Old Oct 5, 2005 | 06:46 PM
klomast3r's Avatar
Default SRS light on steady and dead horn. related somehow???
car: 00 si.
i dont know if this is a coincidence but after my SRS light came on steady, (no airbag deployed, came suddenly) my horn died as well. Can someone tell me it these two things are tied to each other.
Aleady checked wiring and fuse.. its all good.
I heard it has to do the steering reel which means taking the steering off. Is this true? Thanks in advance.
Old Oct 5, 2005 | 06:49 PM
ferchoz's Avatar
Default Re: SRS light on steady and dead horn. related somehow??? (klomast3r)
Check this out....
https://honda-tech.com/zerothread?id=1278108
Old Oct 5, 2005 | 06:51 PM
EeeJayEight's Avatar
Default Re: SRS light on steady and dead horn. related somehow??? (ferchoz)
both are on the cable reel... good chance they are related
Old Oct 5, 2005 | 07:22 PM
suspendedHatch's Avatar
Default Re: SRS light on steady and dead horn. related somehow??? (EeeJayEight)
On the EG they're on the same wire harness. It's probably the same way for your car.
Old Oct 5, 2005 | 09:48 PM
D50boy's Avatar
Cable reel 100%. I've had to change 2 of those bastards. Your cruise control won't be working either.
To get the light off, you'll have to get the SRS computer reset by either a dealer or a specialty shop. That'll cost you about $80 It's shitty. I saw a trick on doing that with a jumper wire, but it has the possibility to blow the bags.
BodyKits NW
14
Feb 23, 2006 05:17 PM
klomast3r
Oct 6, 2005 03:11 PM
klomast3r
Sep 13, 2005 08:26 PM
TougeToad
Jun 5, 2004 07:22 PM
Nuts
Jul 31, 2001 06:26 PM
